Dell Dimension 4500 PC Desktop
Problem for Dell Dimension 4500 PC Desktop
It shows me always limited connectivity
By bhavininusa on Oct 07, 2009
it shows me always limited connectivity
Comments:
Oct 07, 2009
- I think you should try to open CPU and find what kind of NIC you are using.then find the suitable driver of tht NIC card.
Solution #1
posted on Oct 07, 2009
Not Rated)
rams143
Rank: Wiz  Dell Computer Hardware  Expert
Rating: 82%, 27 votes
First try to determine whether you can connect to the Internet loadTOCNode(2, 'workaround'); You should first try to determine whether you can connect to the Internet. If you can connect, the error message is obviously incorrect. If that is the case, you might want to disable the error message. To disable the error message, follow these steps.
  1. Click Start, and then click Run.
  2. In the Open box, type ncpa.cpl, and then press ENTER. The Network Connections dialog box opens.
  3. Double-click Local Area Connection, and then click Properties.
  4. On the General tab, click to clear the Notify me when this connection has limited or no connectivity check box.
  5. Click OK, and then click Close.
Check for other causes and solutions loadTOCNode(2, 'workaround'); If you cannot connect to the Internet, you have to find the reason. Realize that the reason may not be with your computer, but may be an issue with your Internet service provider (ISP) or with issues on the network at your work. Therefore, for some of these solutions, you might need help from your ISP, or, if your computer is part of a network at work, you may have to ask your network administrator for help. Contact your ISP service loadTOCNode(3, 'workaround'); If you use an ISP to connect to the Internet, before you go any further, first contact your ISP to see whether it is experiencing any problems. If the ISP has problems, wait until the problems are resolved before you continue to troubleshoot. Check the hardware devices loadTOCNode(3, 'workaround'); If you still cannot connect to the Internet after you have confirmation that your ISP is not experiencing any problems, manually check the hardware devices on your small office network or your home network for problems. For example, if a hub, router, modem, or access point is installed on your network, check that it is connected correctly, and that it is turned on and functioning properly. The solution might be as simple as turning on or restarting a hardware device, and then restarting your computer. For more specific troubleshooting information about the hardware devices that you are using, refer to the hardware documentation for your devices. Run the Network Diagnotics tool loadTOCNode(3, 'workaround'); If checking and restarting your hardware device did not resolve the issue, your computer may have a networking problem. For example, your computer may not have an IP address or your TCP/IP settings may be corrupted.
There are tools available in Windows XP that you can use to help you diagnose and troubleshoot networking problems. To use the Network Diagnostics tool to determine the source of the issue, follow these steps:
  1. Click Start, and then click Help and Support.
  2. Under Pick a task, click the link to Use Tools to view your computer information and diagnose problems, and then click Network Diagnostics in the list on the left.
  3. Click Scan your system. The Network Diagnostics tool collects configuration information and performs automated troubleshooting of the network connection.
  4. When the process is complete, look for any items that are marked "FAILED" in red.
    Note If you do not see any categories that failed, please see the "Additional troubleshooting information" section for more information about how to troubleshoot network problems.
  5. Expand a category to view the testing results. For example, to check the results for TCP/IP settings, expand the Network Adapters section. Then, check whether a network adapter has failed.
  6. You can use that information to try to resolve the issue yourself, or you can provide the information to your network administrator for help. If you are not sure how to use the results from the Network Diagnostics tool to resolve the issue, see the "Next steps" section for help.
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 4500 PC Desktop
Questions and Unsolved Problems for Dell Dimension 4500 PC Desktop
Do you recommend Dell Dimension 4500 PC Desktop?
Answer
Answer
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Answer
My Imation flash drive does not recognize the password. How can I read it ?
Answer
how do i make adjustments to the dclcd s1702d monitor. the screen is completely light green. i get... (More)
Answer
no sound on 17 inch LCD Monitor , Model LCm 17v2
Answer
how do i get diagrams for my car without having to pay for every little detail ...ashley
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 4500 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
