Question about ViewSonic Computers & Internet
I just bought a Viewsonic VG20wm 20" monitor. The disc is damaged and I can't download the software. Can you direct me in the right direction?
  • 2,727 Answers
Try the Viewsonic support website
http://www.viewsonic.com/support/downloads/
Posted on Oct 07, 2009
Windows 7 drivers
http://www.viewsonic.com/products/va926.htm
Download drivers manually by going to this address direct, manual guide, software and driver updates are included
Feb 24, 2012 | ViewSonic VA926 LCD Monitor
Have just upgraded to windows 7 and my Viewsonic vx715 is only recognised as a generic PnP monitor and I can't load drivers from disc supplied. monitor is approx 6yrs old and still going fine!
In most cases you don't need the drivers for a monitor to work completely fine. In order to obtain your drivers you can always check the manufacturers website and they should have drivers listed, in your case they do. Although I couldn't locate VX715 i found many VX models in the driver search. There should be one that works fine, just make sure you download the right right IE: windows 7 x32/86 if your running a 32-bit operating system, or windows 7 x64 if you are running a 64 bit operating system. Here is the website I located http://www.viewsonic.com/support/downloads/drivers/
Jan 09, 2011 | ViewSonic VX715 17" LCD Monitor
ViewSonic VG2030wm speakers not working
you are unable to get an image on your ViewSonic monitor, first check that the necessary cables are attached correctly and that the proper drivers are installed. ViewSonic offers drivers for download directly through its website (see Resources).
Some LCD monitors use a VGA input while others take advantage of the newer DVI interface to provide a connection to PCs (some ViewSonic monitors offer both types). When connecting your monitor for the first time, you'll need the right type of cable for both your monitor and computer. In some cases an adapter may be necessary to convert the DVI signal from your monitor to work in a VGA input on your PC.
Check that the VGA or DVI cable is tightly attached to the back of your monitor and to the back of your PC. Use the small thumb screws on the ends of the connectors to keep everything tightened in place, which will prevent the cable from getting loose.
ViewSonic monitors also use a power cable to plug into a power source. If the power light does not comes on, check that the power cable is inserted fully into the back of the monitor and that it is plugged into a working wall outlet or a reliable surge protector.
Mar 06, 2010 | ViewSonic VG2030wm LCD Monitor
Vg2230wm monitor Will not power on
probably your power supply. Is it a cord direct from plug in for is there a box between where you plug it in and then a small round end that goes into the monitor. This would be the good news. If it plugs in direct then that means the power sopply is in the monitor itself which means more expensive to fix
Aug 05, 2009 | ViewSonic VG2230WM LCD Monitor
White screen, power switch not functioning.
Unplug it, reset it. Did it come with install disk? Try running that with your old monitor. The system may not recognize it as plug and play or the monitor may be defective. Call Tiger Direct or whoever you bought it from for support.
Jun 24, 2009 | ViewSonic VA1912wb 19" LCD Monitor
I need sofware of my viewsonic
The links below are two picture of the CD came together with the viewsonic monitor.
http://i590.photobucket.com/albums/ss341/VHC08/VX2235CameraAssistantSoftware.jpg
http://s590.photobucket.com/albums/ss341/VHC08/?action=view&current=VX2235Driver.jpg
If you happen need the driver only viewsonic.com has it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.viewsonic.com/products/archive/vx2235wm.htm
X2235wm User Guide, English PDF: 513KB
The CD contain Camera Assistant Software is only 18M, which is an executable file. The software is not too impressed to me. The other CD is the driver disc. It also has a pdf owner's manual and the Adobe reader 4.0
View More Drivers/Utilities »
Jun 03, 2009 | ViewSonic VX2235WM Monitor
External Monitor connection issue
There is only one way to connect an external monitor to a laptop.Most laptops have an "FN" key. by simultaniously pessing the "FN"key and F7 key it toggles from laptop to external to both each time you press the keys.
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
