Question about Nikon Coolpix P50 Digital Camera
Zoom rocker not responding, OK botton not working, 4 way controller behaving strangely. shutter/on:off reset did not work.
Stuck Zoom Function On Nikon COOLPIX L20 Digital Camera
U obviously broke more that just the lcd screen. Your lens assembly is now fubar so you will have to pay the piper to fix it. Or just get a new camera.
Aug 28, 2017 | Nikon COOLPIX L20 Digital Camera
Power/Mode Dial and Shutter Button
Probably humid penetrated inside the camera and caused the problem.
Jul 25, 2008 | Fuji FinePix S5100 Digital Camera
Zoom Buttons stopped working,manual ok
Your problem is most likely one of three things: the zoom rocker (or wires connecting it to the main control) have gone bad, the zoom motor has failed, or you have bad capacitors in the camera which are causing the controls to not operate as they should. In any case, the camera will probably need servicing to restore it to complete function.
Nov 30, 2010 | Panasonic AG-456 Camcorder
Garmin Nuvi 205 screen freezes
When a Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Feb 16, 2010 | Garmin nuvi 205 GPS Receiver
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
Canon Powershot A1000-IS stuck on zoom plus shutter problem.
hello. If there is a reset, it will show it here in the manual. go to this web address. http://gdlp01.c-wss.com/gds/0300001222/PSA1000IS_CUG_EN_02.pdf hope this helps. Ron
Sep 08, 2009 | Canon Powershot A1000IS Digital Camera
Olympus C-750 shutter problems
Changing the firmware won't change anything. The micro switch may be stuck in the on postition. If you are familiar with micro circuits, you could get the switch from Olympus or USCamera.com and replace it. Or, send the camera to Olympus or an Olympus authorized shop.
Apr 16, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Shutter Problem
I had an Olympus C-3000 this same type of sympton happened to me. I sent it off to Olympus to be fixed (via local camera dealer). When it came back, after about 10 shots, it failed again the same way. Back to Olympus a second time. Came back and failed again after about 10 shots. This time dealer worked with Olympus and I was given a new reburbished camera (same model). This whole thing took about 4 months. Time frame was a couple of years ago.
Sep 13, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Nikon Coolpix P50 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
