Question about JVC Televison & Video
My televison screen has a bright lin going thru the center of my screen and can still hear voices as i change the channels
  • 458 Answers
You have a fault with the frame scanning, this will be caused by either the frame IC chip at fault or a supply feed resistor for this chip will be open circuited. You would will need a multi-meter to check what voltages are on the pins of the frame chip, if the voltage supply is present then replace the frame IC.
Posted on Oct 07, 2009
My t.v. picture goes dark when watching programmes
is it by any changes an LG ? if so its the main av board at fault LG's and some other tv makes have a brightness control that is controlled only by the tv, its to stop light flicker when changing channels and accessing menus. its because the channel change changes screen out put from say 1080i/p to 470 in a split second.
Jun 21, 2017 | Televison & Video
How do I change the DVD audio back to hearing the voices and not just background noices on the movie
Most voice tracks come through the center channel. If you don't have a center speaker hooked up, then turn off or change the surround mode so that the player will put the voice tracks back to the front speakers.
Nov 15, 2016 | Televison & Video
Have a 5 disc DVR / DVD player and only get the soundtrack when I try to play a movie. I do not hear any of the spoken words. Is it a menu item I can change ? If so where ?
Make sure your center channel speaker is hooked up and operating correctly. Most voice tracks are directed to the center channel.
Apr 12, 2016 | Televison & Video
When we watch football, we can't hear the refs on the field. Also during halftime we can't hear the music. Some random things get cut out.
do you have a center channel speaker hooked up? Most voices come through the center channel. I would imagine the surround processor would put the refs on the center channel.
Jan 06, 2013 | Sony STRDH830 7.1 Channel 3D AV Receiver
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
Voices vs. sounds
If you are passing video thru the monitor out to the TV, this will go much easier. First Press the GUI Menu button on the remote. If connected to TV, on screen menu will appear. Go to Manual Setup then (right arrow on the 4 way with the ok in middle) Speaker Settings then Speaker Select then go to Center Channel arrow right again and make sure it's "On" If it is, then go back to the main speaker settings and toggle to Speaker Level. Then select center channel and arrow right turns volume up. If you still have no audio, post a comment and I can help you troubleshoot further. Hope this helps
Nov 19, 2009 | Yamaha RX-V496 Receiver
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
No picture on Phillips 20in TV
Your previous adaptor may have been damaged by the failure of an internal component in the set.
Look at your LCD screen from a shallow angle to see if you can spot any 'ghostly' images on the screen when it is turned on and has audio present. If you can, then either the fluorescent backlight has failed or the circuit that produces its high voltage. I've yet to see a modern set that even allows the brightness to be turned down so far that no image is present.
Your grandson may be 'off the hook.'
Jan 15, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
Televison & Video Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
