Question about Canon Office Equipment & Supplies
Images are scanning crooked for pdf files
Images are sometimes showing up crooked on a pdf file
SOURCE: LiDE 600DF - Unable to scan
I think I might have solved my own problem, at least for the time being. If my theory is correct, then it might be a permanent solution.
I had been goint through the "CanoScan Toolbox 5" configuration line by line to see if anything would suggest a solution when I noticed that the "Folder for where temporary files are stored" had an enormously long path of C:\Documents and Settings\username\Application Data\Canon\TB50\...... By the time the temporary filename is added to the end, it may have exceeded the permissible length the system can handle. So I changed it to C:\Temp and it all started to work for me.
Worth a try for my fellow sufferers.
Trying4
Posted on Aug 23, 2008
mspcrepair
  • 169 Answers
SOURCE: How to can multiple pages into one pdf file using Lexmark x4530
Open Acrobat. Under "File", click "Create PDF" then "From Multiple Files"
Remember to rate :)
Posted on Oct 01, 2008
  • 6 Answers
SOURCE: Scan a Multipage Document into a Single File
My scanner is a Cannon but the basic jist of what your trying to do is universal. You need to open up the software for the scanner and look for an icon that says scan to file. It sounds like you have already done this. If so you are very close in the step I mention to the setting you need to scan multiple pages into one PDF file. Once you find the setting to scan multiple pages be sure to not click "FINISHED" until your last page is scanned in.
LB
Posted on Nov 30, 2008
SOURCE: Canon CanoScan LIDE 25
Use the PDF function of the CanoScan Toolbox. On the options screen for a pdf, click the drop down box next to “Save as Type:”. Select “PDF (Multiple Pages)”. This option causes CanoScan to stop after each page is scanned and ask if there is a next page or if you are finished.
Posted on Dec 05, 2008
melnavz
  • 1226 Answers
SOURCE: Scan to PDF File
You have to save your scan to PDF file type. after the system finished saving the file it will ask you again want to scan another pages. replace the page in the scanner and then click to continue.
the saving of file will on the next page of the first file name.
you're own your way.
melnavz
Posted on Jan 23, 2009
How do I scan to PDF when it is not a choice on the SCAN Menu on my HP Photosmart C6280 all-in-one printer?
Hey morten. You cannot scan to a PDF file as scans are automatically made into images. You CAN however create a new PDF file using Adobe Acrobat and putting the image on it then saving.
Have fun :)
Aug 23, 2011 | HP Photosmart C6280 Printer
I am having trouble scanning text documents into pdf format. The pdf format type does not show up as an option to use. Also, scanned images are hugh files 8 -10 Mb. Help!
Good Day Agcarson!
It will be easy to provide you the answer if you mention the brand and model of your printer and your operating system.
Please post back.
Jul 01, 2011 | Office Equipment & Supplies
I have Word 2003. I can't edit Word file converted from PDF file
try using microsoft office live i find this a fantastic tool without having to spend big bucks on buying the whole programme for 2007
Oct 30, 2009 | Microsoft Office Word 2003 for PC
Highlighting a graphic or scanned text in pdf file
If the text is editable you can use the TouchUp Text Tool.
For images use the TouchUp images tool.
Both are located in the Tools Pallet under Advanced Editing.
Oct 21, 2009 | Adobe Acrobat 7.0 Professional
How do I scan multiple pages into one document
When Save as PDF file is selected: The Save as PDF file dialog box opens. Specify the file type, file name and destination folder.
Select from the following PDF file types:
PDF When multiple images are selected, each image is saved as a separate PDF file. PDF(Multiple Pages) Multiple images are saved in one PDF file. PDF(Add Page) Selected images are added to a specified PDF file. The images are added to the end of the PDF file. You cannot rearrange pages of the PDF file to which images are added.
Oct 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Dec 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Printer
try printing a test page. Make sure you have the right driver for your printer. Make sure all connection are secure and tight.
Mar 27, 2008 | Compaq Inkjet IJ650 Printer
438 people viewed this question
old marine
old marine
