Question about Maytag Neptune MAH5500B Front Load Washer
Drum not spinning at all during the wash cycle.Control panel was just replaced and the machine stops at the same place in the cycle as the old control board.
    President:
  • 1,304 Answers
Just a guess lol
but when you replaced the control board to you/him replace the wax motor lock
check the control look for the burn if it is on R-11
the n you will need to replace the lock
Posted on Oct 07, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
Kenmore heavy duty 2 way tumble washing machine
You may have a broken inner tub spider. Check for play between the inner drum and the outer tub by moving the inner drum up and down.
If there is excessive play, the spider is broken causing an unbalanced load and therefore no high speed spin can be achieved.
In this case the inner drum would need to be replaced, which means taking the machine almost completely apart. A good tech can do it in about 1.5 hours.
Jan 16, 2009 | Kenmore 44102 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
