I recorded a singer for five minutes on my camera and when i played it back it worked ok but since that the picture is still there but no sound can u please let me know what i can do
The five-minute limit has nothing to do with the memory card or the video resolution. In some parts of the world video cameras are taxed at a higher rate than still cameras. Cameras that can only record videos up to five minutes in length are not considered video cameras and thus are taxed at the lower rate.
When was the last time you saw a movie or TV scene that was five minutes long without any cuts or breaks? It doesn't happen often and very few people find the five-minute limit restrictive.
Video quality is a very subjective thing. The quality is better than that of almost all compact still and video cameras. It's not as good as professional-quality video cameras. Video has a different "feel" from film --- but which is better?
Since the recording length doesn't depend on the resolution, I'd suggest you always record at the largest resolution. Videos can always be shrunk in size --- they can't be expanded.
The amount of recording time on a disc depends on the recording mode selected. The approximate recording time for each of these modes is listed below:
HQ (High Quality): Recordable time is up to 20 minutes.
SP (Standard Play): Recordable time is up to 30 minutes.
LP (Long Play): Recordable time is up to 60 minutes.
NOTE: If you record in LP mode, the quality of the scenes may be degraded, or scenes with quick movement may appear with a block noise when you play back the disc.
Fortunately they are still making 8mm camcorders usuallyrunning less the $200 to replace. It could be more cost effective to get a new model for that price as well. I couldn't record on my Sony 8mm camcorder anymore after five years of use and over 100 tapes that I had recorded. It's plays back but that's about it.
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera.
Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos You can record and play back sound memos for your photos while you view them on the LCD screen. 1. Turn the Mode dial to playback mode. 2. Press the MENU button. Playback Menu 1 is displayed. 3. Select Sound Memo by using the u d buttons, then press the r button. 4. Press the OK button and then start recording. 5. When you are finished recording, press the OK button. You can play or delete the sound memo or record a new memo. 6. Press the MENU button twice to exit the menu. When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK button to play the sound. Note: You must have at least one photo saved to record a sound memo.
