Question about Bernina Sewing Machines
I have a Bernina Artista 730. Very few inches of
I have a Bernina Artista 730. Very few inches of sewing/embroidery the viewer states "Please check lower area of lint or stray thread. If bobbin is emply, please rewind bobbin." I have done this so many times and nothing different happens. I have taken it to a Bernina dealer twice and has not been fixed. Any suggestions? Thanks.
    Novelist:
  • Bernina Expert
  • 166 Answers
It is likely that your bobbin sensor is either in need of a clean or is faulty. When you drop the bobbin door, the bobbin thread sensor is a black plastic 'box' on the inside of the bobbin door and attached to it. Look carefully and you will see a small lens and an opening next to it - these are the optical parts of the sensor - make sure there's no fluff or dust obscuring the optical parts - give it a brush with your fluff brish and clean the lens very gently with a cotton-bud. Dont use any chemicals or cleaners on this part. If the problem remains after this, the probability is that the sensor is faulty or the sensor connector cable is damaged. The cable runs the full length within the free-arm cover and up to the top of the front panel and I've come across a couple of similar machines where the service person has replaced the free-arm cover poorly and the cable has become trapped in the bottom drive mechanism. If cleaning fails to work, get your machine checked-out by a competent Bernina engineer. In the meantime, you can disable the error message, but dont just use this as a total solution.
Posted on Oct 17, 2011
I know this is a long-overdue response, but maybe it will help someone else. I had the same problem, and it turned out that the cause was that my bobbins had oxidized. Rubbing them with a bit of steel wool or fine-grain sandpaper did the trick, and I was up and running again.
Posted on Feb 06, 2011
  • Rick Beament Oct 17, 2011
    Bobbins are sufficiently cheap that I'd recommend just getting new ones rather than sandpapering ones that have gone rusty. More importantly, you need to question why they went rusty in the first -place ! If the rest of the machine is OK, it's probable that your sweat is a bit acidic - a fairly common problem - this can lead to the bobbin case and even the hook/shuttle becoming rusty, which is impossible to correct by using sandpaper ! If you are seeing rust or discolouration of the bobbin / bobbin case, it can be reduced significantly by washing your hands and thoroughly drying them before messing-about with the bobbin threading etc. - this is a really worthwhile thing to do in the long-term as it will also protect the hook race area of your machine which could cost money to put right if it gets rusty.
2 Suggested Answers
RickE1
  • 202 Answers
SOURCE: Viewer states problem - but cannot correct.
Hi, if you look in the bobbincase you will see a round spring. Sometimes this gets moved and it blocks the hole the sensor reads through. Clean inside the bobbincase with a q-tip. Also clean the sensor lens on the door with a q-tip. Also try rewinding a bobbin but don't start with the thread through a hole in the bobbin.
Hope this helps.
Rick
Posted on Oct 08, 2009
I am doing some machine embroidery on my Bernina Artista 730 and the upper thread keeps breaking. I have changed the needle and rethreaded many, many times!
use a bigger eye in the needle and loosen of the needle thread tension a bit
needles are all the same length but come with various size eyes to accommodate thicker or thinner threads
use scrap material until you get a good combination
Jan 04, 2017 | Bernina Sewing Machines
Why doesn't it recognize that an embroidery hoop is attached?
Perhaps this will help:
My Embroidery Haven View topic Bernina 180
Bernina artista hoop not recognized
You can also try contacting the Support group at Bernina.com or your local Bernina dealer
Feb 24, 2016 | Bernina Artista 180
Is bernina artista 180 embroidery module compatible with bernina artista 170
Yes, The BERNINA Artista 180 and the BERNINA Artista 170 do in fact use the same Embroidery Module.
Sep 28, 2015 | Bernina Artista 170
Bernina Artista 180 firmware question: I sold a Bernina Artista 180 sewing/embroidery machine. This machine was from 1999 and never had any firmware updated. The embroidery module was damaged in sh
I'm not exactly sure what you need but I'll give you a web site where I believe you will have good results:
http://www.ebay.com/bhp/bernina-software
Dec 15, 2014 | Bernina Artista 180
With embroidery card inserted into module, no motifs appear on the display screen.
Here are two other possibilities other than electrical problems with your Bernina. There are embroidery design cards that were made for the 200 & 730 that simply do not work in a 180. There is nothing marked on the card or the packaging that will tell you what model machine the card will work in. I sold a bunch of my design cards on eBay last winter and I tested all of them in both a 730 and a 180 before making the ad discription. I found that most of the design cards worked in the 180 & 730, but there were a few that only worked in the 730. So if your design card is one of those that won't work in a 180, that could be your problem.
You did not say if you have other design cards that do work or there is only one you tried. Possibly the card itself is bad.
A static shock to the card could possibly damage it.
So if you take your machine to a dealer to have it looked at, take your design card along.
The 180's memory for storing designs is located in the embroidery module, not the machine itself. If that memory is filled up with other designs this can cause a problem.
So your problem is most likely with the design card or with the embroidery module. Should you need to get another embroidery module, that module needs to be the same version number as your machine or it will not work. I have a. video posted on YouTube that shows you how to check the version number of your machine and module. That information is in my "Bernina check hours 165, 170, 180, 185" video. Put that in the YouTube search box and you will find my video. Plus I have other helpful Bernina videos posted.
Aug 14, 2014 | Bernina Artista 180
The embroidery unit no longer registers on my artista 180 when I connect it. I borrowed a friends embroidery unit and it worked so i assume it not the 180 which is the problem. What should be my next move...
If you bought the embroidery unit with the machine, I would try to take it back to the place of purchase & ask for a sewing tech to check the machine & unit for you.
I recently had a similar issue with my machine-took it to a local bernina agent & within a week, it was back in my sewing room, at no cost to me. I hope this helps you, & yes I have a 180 with the embroidery unit like you mentioned
Jan 05, 2011 | Bernina Artista 180
Artista embroidery program version 3.0 and Windows 7
For other versions and probably yours...
You'll need the following service packs to use BERNINA Embroidery Software V5 aand under Windows® 7 / Windows Vista™ operating system:
  • Service Pack 2 for BERNINA Embroidery Software V5 (V5.0W)
  • Aurora driver for 64-bit Windows® operating systems
  • Latest dongle driver
  • EConPC 3.1 & ADX 7.14
You'll find them at www.bernina.com\downloads
Hope this helped.
Rick
Jul 04, 2010 | Bernina Artista 180
I am looking for a video or preferably a person who can give me a couple of intro lessons on the embroidery function on the Bernina artista 180. I have been using it for sewing but have been intimdated by...
I'm selling Bernina Artista instruction DVDs on Ebay, one is only for the embroidery part, which teaches very well how to do it. It is for the models 165, 170 and 180.
Jan 26, 2010 | Bernina Artista 180
Hope this helps.
Rick
Oct 07, 2009 | Bernina Sewing Machines
Sewing Machines Logo
410 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
