Question about Intermatic T104 24h 208-277v Mechanical Time Switch
Need a new plastic shield that covers the wires ... where can I get one? Thanks.
    Problem Solver:
  • 18 Answers
U can use plastic or metal from wilkos
Posted on Oct 08, 2009
Purge solenoid location 2008 torent
Evaporative Emission Canister Purge Solenoid Valve Replacement
Remove the fuel injector sight shield. Refer to Fuel Injector Sight Shield Replacement. Disconnect the engine wiring harness electrical connector (4) from the evaporative emission (EVAP) purge solenoid.
Remove the oil fill cap. Lift upward and remove cover from ball studs.
The purge solenoid is under the plastic cover on top of the engine .
Disconnect the EVAP pipe quick connect fitting (1) from the EVAP purge solenoid. Refer to Plastic Collar Quick Connect Fitting Service.
Disconnect the EVAP pipe quick connect fitting (2) from the EVAP purge solenoid. Refer to Plastic Collar Quick Connect Fitting Service. Remove the EVAP purge solenoid bracket bolt (3). Remove the EVAP purge solenoid.
the purge
Sep 20, 2014 | 2008 Pontiac Torrent
Were is the spark plugs
Open hood. Remove large plastic shield covering engine. Under the shield are two rectangular packs sitting side-by-side. The four spark plugs are under these two packs, deep in the engine - you will need an extension (and possibly a piece of hose) to get them out. Be careful not to strip the threads in the engine when installing new plugs.Thanks
Feb 21, 2011 | 2003 Kia Spectra
Need directions on how to change the starter on a 1994 cadillac deville
On a 4.9 v8 this is relatively simple
Step 1.... Before you get under the car, Disconnect the battery and look for the metal shield. The best way to find it is to follow the red (power) cable from the battery. It goes straight to the starer. You want to take out the metal shield, but you will only be able to take out the only accessable nut from the sheild from the top. The other will be from below (later). Take out the 1st connector/nut holding the shield. This should be located by the radiator...you will see the metal shield is protecting the wiring from burning on the exhaust manifold.
Step 2...Then raise the car on the lift, take off the long / wide plastic shield under the radiator (allowing manuverability and you to see what you are doing). Then remove second plastic shield covering the starter.
Step 3...This will allow you to take out the 2nd bolt holding the metal shield (from step 1) protecting the wiring harness.
Step 4...Then you will be able to unfasten the wiring and bolts to remove the starter.
Step 5...Replace with the new starter, reconnect everything and bolt it ,etc. Dont forget to put all the sheilds back in place and make sure the wiring harnesses dont touch the exhaust manifold.
Step 6...Lastly, lower the vehicle, raise the hood and dont forget the nut on the metal shield !
Step 7...Reconnect the Battery
Step 8...START YOUR ENGINE!!! YAY!!!
Jul 30, 2010 | 1994 Cadillac DeVille
How do i remove and replace front wheel bearings on my motor cycle, it looksw like ity has a dust cover which needs to be removed first but how?
the dust cover is part of the bearing (ie: its black plastic) just knock out the bearings and fit new one's they will also have new bust covers,,,,check the bearing numbers they should have a,,Z or a ZZ on the end of the bearing number some thing like
6202ZZ! the Z is for a shielded bearing and ZZ for dubbel shielded bearings witch your's should be,
Mar 10, 2010 | 2004 kawasaki ZX-10R
How do i change a headlight in a 2002 sunfire
    1. Step 1 Lift the hood and locate the air intake splash shield. This is the plastic cover running along the front rail of the vehicle and covering the headlights access. You will notice some plastic pins holding down the splash shield. Simply lift the head of each pin up about a quarter of an inch and pull it out of the pre-drilled holes. Remove the splash shield when you've extracted all the pins.
    2. Step 2 Locate the two retaining bolt at the top of each headlamp (on the left and right side top) on the front frame rail. Remove them with a ratchet and socket.
    3. Step 3 Slide the headlight assembly out being careful not to scratch the bumper.
    4. Step 4 Unplug the wire from the back of the headlight. You may convince it with the screwdriver to release the tabs from the lock clip on the headlight, but be careful because it's plastic.
    5. Step 5 Turn the bulb retaining ring to the left and remove it. The old bulb will fall out now.
    6. Step 6 Insert the new bulb being careful not to touch the glass part of the bulb. Halogen headlights can be compromised or damaged by oils and alkaline in our skin. Place the retaining ring over the headlight and turn to the right and plug the wire back into the bulb. It would be a good idea to turn on the power and check the headlight now to make sure it's working properly before putting everything back together.
    7. Step 7 Replace the headlight assembly retaining bolts.
    8. Step 8 Replace the splash shield and insert the pins. Pushing down on them in the pre-drilled holes is all you'll have to do to lock them.
    9. Step 9 Remove any tools you might have left under the hood and close it.
Nov 21, 2009 | 2002 Pontiac Sunfire
I want to replace ignition lock cylinder on my 1998 Toyota 4Runner do I need special tools to do it? or what are the steps to do it? thanks.
You have to remove the plastic cover underneath of the steering wheel, after that the metal shield behind the plastic cover. When you remove the shield you will get access to the ignition lock cylinder. Disconnect the wire harness, remove the cylinder, install a new cylinder. Connect the wire harness, install the shield, install the plastic cover.
PS: Before start write down the code for your stereo (if you have one), disconnect the negative cable from the battery. Be careful when you work around the air bags.
Sep 17, 2009 | 1998 Toyota 4Runner
Cant change a blade on 500watt pendulum jigsaw fmtc500js
Hi
There is a click mechanism to replace the blade at the top of the blade.
best regards savumihai71
Jan 18, 2009 | Saws
I need the plastic cover that goes over the mini casio calculator hr-8tm 12 digit
I would contact INVISI SHIELD , search for them on Google. this company is great I got the shield for my Iphone and they use the same grade plastic that they use on helicopter blades and its so strong you can rub your keys , a knife and many other coins / items and it wont ever scratch your product. These guys have almost any type of cover for any product and they also custom make them and you cant even notice any bulkyness or change on the look of your product, hardly even visible that you have a cover. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Aug 11, 2008 | Casio Computers & Internet
Infiniti M35 - change headlight Bulb
Take the wheel off the side with the burnt out bulb. Next pull the 6 plastic rivets out of the front fender well shield. Take the screw out of the shield above the 3 rivets along the inside of the fender edge, Pull the shield back starting at the top where it's tucked under the back portion of the liner shield. Unscrew the top plastic cover, twist the connector counter clockwise and pull it off the bulb. Then unclip the bulb and pull the bulb out noting the groove position for reinstalling the new bulb in the housing. There is nothing simple about your bulb change. The dealer price of the bulb is around $245.00. Don't break the new bulb trying to guess when it's seated properly!
May 18, 2008 | 2006 Infiniti M35
Intermatic T104 24h 208-277v Mechanical Time Switch Logo
66 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
