I have tried re-tuning my mums tv but all I get now is no signal with a countdown from 5 minutes before it switches off. I have tried going back into menu then settings etc but I'm not getting this come up. I'm getting a box come up with headings Picture, Sound, Feature, Install, Program Table and Sorce:TV.
  • 458 Answers
It sounds like you are not getting a signal from your antenna connection. Check the cable & connector which goes into the back aerial connection of the TV. It will switch off after 5 minutes because it is not receiving a signal & if you are getting the menu box then the TV is working ok.
Posted on Oct 07, 2009
Screen freezes BBC Channels only. Unfreeze by switching off TV. Handset and TVs buttons fail to work. Minutes laterscreen freezes again. No problem with non BBC channels
turning tv off and on wont make it better
you on roof antenna or a cable tv
if antenna only
you may be in weak signal area
or a new construction site or buildings deflecting the signal
antenna problem or needs upgrade
go back to TV set up and re-tune tv to bbc if possible
if it freezes then you know its an interrupted signal
Mar 26, 2017 | Televison & Video
Trying to set switch for 5 minutes , and i only get 30 seconds or 15 minutes
Which brand and model number specifically?
Leviton: 1-800-824-3005
Leviton Decora manual says:
"PR180 operates by detecting motion (such as body heat) within its field-of-view (area of coverage) and automatically switches lights ON. When motion is no longer detected, lights remain ON for a selected time and automatically switch OFF.
Adjustable light and time-delay controls are located on the front of the device."
The manual is not specific about set times.
In any case, the device has off-delay timing circuit, so once infrared heat is no longer sensed, the delay period begins, and once the delay period expires, the device is switched off.
Delay timing circuits are common for many home and industrial applications.
As a general rule, delay timers can be set for different time durations, however the Amazon page that sells PR180 product does not specify available time settings either.
Legrand RW3U occupancy sensor spec sheet says adjustable time delay 15 seconds 5 minutes, 15 minutes and 30 minutes
http://www.amazon.com/Legrand-RW3U603I-Occupancy-Vacancy-Decorator/dp/B005FMLL5G
Delay switches
Here is manual delay-time switch Tork SS20 SS13 where you can 'fine-tune' the delay circuit, but my experience is that exact 5 minutes is not easily set:
http://waterheatertimer.org/images/Paragon-ET-series-243.jpg
GE 15318 switch offers 5 minute, but there is no guarantee that you can get 5 minutes exactly:
http://waterheatertimer.org/images/GE-15318-countdown-timer.jpg
My conclusion is that there are very limited delay-time choices with this model number, or device is defective and suggest to call Leviton.
Sep 23, 2012 | Leviton R01-PR180-1LI Decora 180 Degree...
We have gone to Step 3 and hit Cable but we should have skipped it. Now we have No Signal and cannot go beyond Step 5. It says No Signal. Please advise. Thank you,
Hello, try resetting back to factory default. If it asks for a code its usually 0000. You can acess this through menu. After that try auto tuning and that should work. If all else fails switch it off at the point and leave it off for a minute and switch it on and see if that resets it.
Mar 27, 2011 | Samsung LN32A330 32 in. LCD TV
Our new digital LCD tv occasionally suffers from picture breaking up and even total loss of signal, after some time, 5 to 15 minutes the signal is restored. Fiddling with the aerial run and connections has...
Tune to a strong channel.
Go into the menu. Find the Channel or Antenna whatever your tv calls it. Set the signal strength display.
If the signal strength show good and your picture is lost then a problem may be in the tv.
More than likely the antenna is not picking up a strong signal. Try rotating it some.
You can go to www.tvfool.com to see what stations are in your reception area.
Feb 13, 2011 | Televison & Video
How do I set the time on the 61048 SUNBEAM DIGITAL TIMER
This is a countdown-type timer, for precise cooking times, etc. Press hour and minute buttons to set time.
Press start button to begin countdown.
Press hour and minute buttons same time to reset timer.
Timer beeps each 5 and 10 minute intervals during countdown.
This timer does not connect to any electrical device, has a magnet on back, and has internal battery operated.
For large image of timer:
http://www.oneida.com/oneida-digital-clock-timer.html?utm_source=Shopping.com
Nov 06, 2010 | Sunbeam 6 Robinson Home Digital Timer
I ws using my humax to watch a programme, when the picture froze.
It can sometimes happen if the signal level drops & the TV digital decoder cannot pick up the strength of the signal when the transmission is back to normal. Switching on & off again resets the processing again. This is a similar effect that can happen with cable or sky transmissions also, it acts the smae way as sometimes having to re-boot your PC if that should crash. It is not necessarily a fault with the TV.
Oct 24, 2009 | Humax Televison & Video
No signal recieved
I am getting a "no signal" across the the screen of my 42lg30 TV
Oct 01, 2008 | LG 42PX5D 42 in. Plasma HDTV
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Jan 08, 2008 | Orion HDLCDVD225 22 in. LCD TV
Duraband tv counting down!
wow is that a joke a 14 in tv????????????? i have no coment for a loser like you
Jan 07, 2008 | Durabrand DWT1905 TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
