Question about Samsung L200 Digital Camera
Flash won't work at all. Won't even force flash.
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
My flash won't pop up.
Theres a button on the side of the camera with a lighting bolt on it push to open leave lens cap on to test then go to menu look for flash/ bracketing and set to open
Dec 19, 2012 | Nikon D60 Digital Camera
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
I know I need to upgrade my flash player and a 11player won't work so how do I find a player number 9 for my cell phone its a android
To upgrade flash player, your mobile should have appropriate hardware to support. If you are trying to upgrade from market,it upgrades. But won't work. So you need to uninstall the upgrade and switch back to the older version of flash. Otherwise upgrade the required hardware for Flash to work.
Thanks,
Mr.Maduraikaran.
Oct 19, 2011 | Jaytronix Android Apps
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
I recently bought a Scosche Digital FM Transmitter Model FMTD8/FMTD8R. I loaded my 8GB San-disk flash drive with music but the transmitter won't read it.. doesn't even detect the flash drive being...
wma files won't be read, only mp3 files, in my experience. My 512 mb SD card works, but it won't read my 8 gb SDHC card. I suspect it can't manage SDHC (high capacity) cards. I haven't tested yet, because as it turns out, neither can my computer... I think I'll fall back to a flash drive.
Jun 11, 2011 | GPS
My laptop won't connect to youtube for some reason even though it is connected to the dongle it still won't connect to youtube. can you please give me a solution to this or at least tell me why...
Hi
Please check you install the abobe flash player, if not install the install the latest flash player and try again otherwise please send me the your " Error"
Jun 02, 2011 | Computers & Internet
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
My powershot G9 built in flash is not working
There is a switch on the hot shoe to detect the external flash. When you use an external flash, the switch will be pressed down, then the unit will bypass the internal flash and won’t let it fire. If the little switch gets stuck somehow, you won’t get your internal flash on.
Check this switch on the hot shoe (either on the left side or the right side), blow some compressed air then plug/unplug an external flash several times. Hopefully you can get it back
Feb 06, 2009 | Canon PowerShot G9 Digital Camera
Samsung L200 Digital Camera Logo
19 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
