Question about D-Link DI 514 Wireless Router (DI-514)
D-Link Wireless router managment problem
Logging in and management of the router settings using the PC ethernet connx'n is very slow. The same tasks using a laptop through the wireless ports is virtually instantaneous.
I've tried swapping the port and a different cat5 cable to no effect.
I haven't yet checked or updated the firmware as this carries some risk.
Can you please speculate what may be causing the really slow response(over 1 minute to fully load a router management page) that is evident when using an ethernet port, but not when using wireless?
  • 79 Answers
You should have tried the followings to eliminate some possibilities:
* Hard reset your router by using a niddle or something to press the botton on the back or underneath of your router.
* Use another laptop or desktop to access the management interface, see if it's getting better, or back to normal
* If you familiar with the Terminal funciton in windows system, you can revive your router even you got it bricked by upgrade the firmware.
Posted on Dec 24, 2007
My router has been set up for a few years now to my current laptop however i have gotten a new laptop plus a wii and would like to sign in to my wireless connection with both but have forgotten the...
You'll need to reset your router to its factory default condition, then re-enter your configuration information (ie, set a new wireless password, etc.).
Use a paperclip or similar item to (while the router is on) depress the "Reset" switch on the back of the router, hold it for 10 seconds, then release. This will reset it so you can reconfigure it as if it was new using the web interface.
Hope that's helpful.
Dec 31, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
My Ethernet lite will not come on on my modem, cannot get online thru this wireless router, tried reconnecting cables and power down the modem per set up instructions that came with the netgear router,...
if your modem has an ethernet connection the drivers should be on the disk provided by the internet provider
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Nov 30, 2010 | NetGear WGR614 Wireless Router
Wireless capability. Device manager says that wireless card is enabled and functioning properly, but it can not find my network. No swith to turn on/off the wireless capability.
First make sure that wireless LED status is on on router.
Then if it is ok then uninstall wireless driver from device manager then reinstall it.
if you haven't driver disk then download from below link.
click here
Then if still same issue then you need to access your router.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings enable wireless
Also change channel type to 3 or 6 or 11 then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 06, 2010 | Dell Inspiron 1545 Notebook
Tp link wireless router Ethernet not working
Make sure the TCP/IP settings on the PC's LAN gets an IP address automatically, don't use a fixed IP address.
Apr 21, 2009 | Computers & Internet
Losing wireless connection after logging off
Log off? Not turn off?
Does the wireless work after you reboot?
If you log off but keep the computer powered it may be a power management issue.
Some network adapters have a setting to allow windows to turn them off to save power.
Go to the Device Manager, right click on the wireless adapter and select Properties.
Is there a Power Management tab? If so, click on it and remove the check mark from "Allow the computer to turn off this device to save power".
Sep 27, 2008 | Belkin (F5D5231-4) Router
Connection
change channels to 1-6-or 11.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter and usb ports in device manager to make sure that windows is not shutting them down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones1.gif in the area and see if it helps.
Mar 08, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Configuring router to work with dsl modem
Make sure that the wep password is correct.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Also, check and see if the usb ports and the device are being shut down to save power, in device manager.
Mar 01, 2008 | Computers & Internet
Zyxel wireless router(p-660hw-t1)
Change the MTU size to your ISP's default!
Jan 14, 2008 | Linksys Wireless-G WRT54GX Router...
Problem withD-Link DI524
Hi Darren-N,
Please excuse some silly question in order to help you.
1- did you connect this router to the adsl/cable modem?
2- does the ISP require you to clone the ethernet MAC address?
3- did you connect the modems ethernet port to the correct port on the router?
4- Is the router seeing an active link to the modem?
5- Is the router configured to be the DNS server or is this disabled.
6- did you enable any MAC filtering or enable any other security features?
7- If it's connected to an ADSL modem through ethernet, does the modem require a keep link alive/active ping so that it does not drop the link?
8- Does the PC the router is connected to have a firewall, if so this might be the problem.
Please describe the set up in as much detail.
Regards,
Spare head 2.
Jan 05, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
Not pickin up signal
Upgrading the firmware (which forced a software reset) solved a similar problem I had with an SMC router. Have you tried logging into your router via an ethernet cable and doing a software reset? If you try this, be sure you have all the information you need to set up your wireless network again because the reset will wipe out all this information.
Nov 12, 2007 | Belkin (F5D7230-4) Router (587009)
D-Link DI 514 Wireless Router (DI-514) Logo
67 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
