Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Older model keyless will not open new craftsman garage opener.
I purchased a craftsman model 139.53930DM garage door opener and my older model 139.53684 keyless opener will not work on it.
  • 736 Answers
Inside or on the back of the opener motor housing or sometimes on a remote receiver (an external box connected to the motor unit and a push button) is a set of switches ... if you take your opener apart you should also see a set of switches ... those have to be set the same way as the opener ... thats the code select ... make sure the battery is ok .. you can check with sears to see if your older remote is compatable ..
Posted on Oct 07, 2009
3 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Posted on Dec 01, 2008
SOURCE: My Sears Craftsman Model 139 53684 Keyless remote
Make sure that when inserting the 9 volt battery that those red & black wires are not somehow pinched, twisted or stretched. I just fixed mine... The battery terminal was crushing one of the wires and preventing the battery to supply power to the keypad. I found it out by NOT securing the battery case door and my opener worked fine. Securing the battery case door with the screw and thightening, my opener DID NOT WORK. It was that simploe of a FIX!
Posted on Jul 06, 2010
I have a Craftsman Keyless entry model 132B2386-6 with flashing lights, wont open. Already put in new battery still doesn't work
Why would my Keyless Entry close but not open the garage ...
www.shopyourway.com > Manage My Life > Questions
Mar 27, 2008 - I have a Craftsman Security+ Keyless Entry, P/N 139.53684 purchased with my ... However, the door will not open, but the keypad flashes as before. ... Check if there is a flashing green light on your wall control in the garage. ... The 2 remotegarage door openers won't open or close the garage door; but the ...
Craftsman garage door opener won't open or close, why ...
Hi, I have a Craftsman 1/2 HP garage door with keyless entry (P/N ... When I click theremote or the wired button, the main lights come on, the motor moves ... Five flashes means that the RPM sensors has most likely stop communicating.
LiftMaster - Support - Videos ' LiftMaster
https://www.liftmaster.com/Customer-Support/Videos
Chamberlain GroupHow to program a wireless keyless entry using your garage door opener's LEARN button. How to ... Why the LED or light on the door control is blinking and my remotecontrol is not working? Why isn't ... Why won't my door fully open? How to ...
Feb 08, 2016 | Building Materials
I can't get my older garage door remotes to program with the new unit.Do I have to buy new remotes?
SORRY TO SAY.THE ANSWER IS YES.
THE NEW OPENERS ARE NOT ON THE SAME FREQUENCY.
YOU CAN PURCHASE REMOTES THAT WILL WORK WITH BOTH OLD AND NEW OPENERS (DUAL FREQUENCY).
BUT, OLD REMOTES WILL NOT WORK WITH THE NEW OPENERS.
Dec 29, 2014 | Craftsman Sears Liftmaster Garage Door...
Ladies / Gentlemen: I have a Craftsman 139.53975SRT1 Garage Door Opener. What is the correct keyless entry pad for this opener? Will a 139.53876 keyless entry pad work with this opener? Thank You! ...
The correct keypad for your opener is 139.53684. The 53876 keypad is an older technology and will not work correctly. If you program it you will find your remotes no longer work and if you reprogram your remotes the keypad will not work.
Sep 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Cannot get remote for garage door to work
push the green button on the opener then push your remote button
Jan 25, 2010 | Locks & Locksmithing
Can a craftsman 953876 keyless entry pad garage door opener work on a liftmaster garage door opener
If both units were manufactured before April 2005 or both were manufactured after that date they should work. If one is older and the other newer than that date they will not work with each other.
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Is there a univeral remote for craftsman garage door openers?
Depends on the age of the opener. The model number is on the end of the opener closest to the door. Using it go to Sears parts and you can find out if the remote is still available.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Program craftsman garage door opener and embedded car door open
Either your car or your door opener is an older model and they are not compatible. Hopefully it is the opener that is older.
Jul 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
288 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
