Can you turn off the power indicator (Vizio logo) light. It is very bright and is in our bedroom
I just placed a piece of black electrical tape over the logo.
Problem easily fixed.
Posted on Jan 25, 2010
    New Friend:
Press the MENU button on the remote. Use the UP or DOWN button to find SYSTEM. Press OK to select SYSTEM. Use the UP or DOWN button to select POWER INDICATOR. Press OK. Use the UP or DOWN button to select the OFF option. Hope this helps.
Posted on May 18, 2015
  • 909 Answers
No, you can either turn it off at the wall, or colour it with a marker pen to dim it a little.
Posted on Oct 07, 2009
How to test Tcon and other board on Vizio television. When I first connect power logo is bright orange, then slowly dims.
That isn't a timing control board issue, see if you have PSON voltage for starters, if you do then test the various power supply voltages, it could be either the main or power board giving issues, but I would bet on the power supply is bad since the logo comes stays on
Jan 31, 2018 | Vizio Televison & Video
Do I need to replace my power board or main board on my Vizio M370NV tv?
If the set powers on, albeit briefly before shutting off, it could either be the power or main process board.
Before going ahead and ordering a replacement main process board for your set's model/chassis series, check the power board and other boards to rule out any possibility of potential failures - if you find the new main board does not fix the issue - next step is to tackle the power and T-Con board(s).
Hopefully in your case it's just a bad main process board that's gone bad and nothing else.
Dec 31, 2017 | Vizio Televison & Video
How do I fix a vizio e320vp tv that turns on and then back off after about 20 seconds
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 18, 2015 | Vizio E320VP 32" LCD TV
How do I fix my lcd tv that won't turn on? It does not appear to be the powerboard.
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
Sep 22, 2015 | Vizio XVT473SV 47 in. LCD HDTV
Mytv has no power the vizio logo does not light at all
You have an issue with the power supply boardif the vizio logo doesnt even turn orange when the cord is plugged in. You can get the replacement power supply board from www.tvcircuitboards.com
Nov 11, 2012 | Vizio VO47L 47 in. LCD TV
Vizio wont turn on
If the logo comes on orange and stays solid ornge when you press power it would indicate the main board has failed. If the vizio light turns white when power is pressed it could be a shorted inverter or an issue with the power board.Need the model number of the set also to assist further with the problem.
Oct 31, 2012 | Samsung LN-S4692D 46 in. LCD HDTV
Vizio back light on, no video
That sounds like a main board failure, I've had a few of those with Vizio sets. But get a proper diagnoses to be sure
Sep 08, 2012 | Vizio VW42LF 42 in. LCD HDTV
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
Vizio HDTV E3DB420VX wont turn on
If your power indicator isn't lighting up, you don't have your 5vdc standby power. You're most likely looking at a power supply issue. Did this happen after a T-storm???
May 11, 2012 | Vizio 42 Class 120hz - 3d Hdtv Lcd...
Televison & Video Logo
3,384 people viewed this question
Top Televison & Video Experts
