Question about KitchenAid Blenders
Dear Sir/Madam: We've had our KitchenAid Blender Model KSB50B4 since 2007 that I've used to blend everything from Marguaritas to soups. The base has always leaked a bit, BUT last night I was blending soup that had been simmering on the stove & the rotating mechanism that turns the blades melted! Rubber melted into the bottom of the pitcher & the rotater was destroyed! I have NEVER seen this before & have never been under the impression that a blender cannot work with hot liquids of any sort. I only knew that one shouldn't fill the pitcher too full as hot liquids expand. Please help! I am without my blender that was very expensive. Now it's ruined & I am extremely unhappy with this product. Thank you, Mrs. Julie Ladeau
Hi, exactly the same thing happended to me. Apparently the repair shop can replace the rubbery bit for $20 (NZ)
Jules
Posted on Jan 24, 2010
Blender not working
Check power to the switch, and from there to the motor.
Jul 11, 2015 | Conair Cuisinart Sbc-1000 Soup Maker And...
Problem with soup mate,all lights flashing but nothing happening
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
May 19, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Oven will not heat up
Kitchen Aid blenders are used for chopping/blending not heating.
Apr 03, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Kitchenaid blender
That part fits the top of the beaker to prevent the foods splashing out when blending.
Jan 27, 2014 | KitchenAid Blender Jar Lid Replacement...
Ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Thanks
Jul 30, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Leaking Blender
yes you have a defective rubber seal on the pitcher base
Apr 16, 2009 | Back to Basics Blender Solution 5500...
KITCHENAIDE BLENDER
sounds like you engage gogs under you canister are slipping or wore out lift up your canister to check them. not sure if your particular model has set screws in them or not look and see might be it hope this helps
Sep 01, 2008 | KitchenAid KSB5 Professional Stainless...
Blenders Logo
664 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
