Question about Refrigerators
Water is pooling in the bottom of the refrigerator. this model does NOT have an automatic ice maker, nor is connected to any water source. model #frt18g4awo
    Scholar:
  • 57 Answers
This is usually caused by the drain tube being plugged. There is usually a collector tray mounted under the refrigerator near the compressor and a small drain tube that runs into the refrigerator. The tube will plug with slime and green mold over time. Without knowing the model or make I cannot tell you for sure where the tray is located. If you find the tray you should see a tube laying into or hanging above the tray and running up to the refrigerator. Clean this tube and the little drain hole in the refrigerator with a pipe cleaner or soft piece of wire. Also check your door seals as a bad seal will also cause excess moisture to form in refrigerator, and children constantly opening and closing will also cause excess moisture to form and if the drain is plugged it will build up in the bottom.
Posted on Oct 07, 2009
Leaking water inside of refrigerator. Ice maker is off and disconnected from water supply. Seals around doors look fine and seem to close tight, no signs of cracking. No cracks in interior of...
Hello Rick,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 27, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Jenn-Air refrigerator, top freezer, older model, frost-free. Ice has started forming on the "ledge" at the back wall where the lowest shelf rests. Then the ice melts and water pools at the...
There is probably a little sediment in the ice maker shut off valve. It's electrically operated whenever the icemaker starts a new batch.
You can try cleaning the valve, but it's typically not worth the trouble. I'd just install a new one. It's easy, typically just a couple screws, an electrical connection and the water connection. To prevent it from happening again, add an in-line filter BEFORE the ice maker.
Jan 31, 2011 | Refrigerators
Stainless Steel GE Profile with Bottom Freezer.
Have you had any cooling problems coincide with the ice problem? if no evidence of temperature variations, you either have a crack in the ice maker mold, causing water to drip into the ice bucket. Or you may have a bad water valve solenoid, not closing completely when the ice maker stops calling for water, overfilling ice maker into the bucket, and further down your freezer.
those are the most common problems, though other odd situations could also be a problem.
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Water on the ice maker doesn't shut off - drips into the ice pan
Most models of Ice makers have an automatic timer for the amount of water that is allowed to enter the Ice Maker tray. If your timer valve is going bad you need to replace it. First I would reduce the amount of water coming from its source. There should be a tapped valve under your sink, connected to your water line. You have to turn the top of the valve clock wise to reduce the amount of water the is going to the back of your refrigerator. That is where you will find the timer valve. Reducing your water flow should help reduce the volume of water being let into your Ice Maker.
Jul 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
I am interested in the lg bottom freezer french door refrigerator but my current refrigerator does not have an ice maker and is not near a water source, since the ice makers are standard on these...
You will want to make sure it stays in the off position or it will constantly cycle thinking it is making ice and burn out the water valve coil. If you are definitely not going to hook it up removing the ice maker will accomplish the same thing and give you a few more inches of storage.
Eric
Jun 08, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice maker won't work
If you are sure that power is getting to the ice maker unit inside the freezer and you're sure that water is available for the ice maker...
Try these next steps:
Follow the water line for the ice maker back to the ice maker water solenoid
Follow the wiring from the water valve to its source - either a timer or circuit board
Check the timer and/or circuit board for any bad connections, burned connections and power to the board or timer. This arrangement can vary by refrigerator model number...
Apr 11, 2009 | Refrigerators
Water of unknown source is on shelves of refrigerator
could it be from the ice maker or the water in the door.
Mar 24, 2009 | Kenmore Refrigerators
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Ice maker is leaking inside
check the distance on the fill tube and the funnel if this is fine look and see if there is ice blocking the hole in the fill funnel and also look into the fill tube for ice let me know what you find
bill
Jul 02, 2008 | Amana ACD2232HR Side by Side Refrigerator
Side by side refrigerator
The ice maker is not producing ice or not enough ice
production.
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
