Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Leaking when we fill it with water it just leaks out my uncle cleaned it once the seals or something was cloged with hair worked good but now its doing the same thing
What goes in the hole on the bottom of the clean water tank? I bought this on a yard sale and there is an open hole in the bottom of the water tank...if I only add about a pint of water and keep it tipped and get it onto the bottom tank really fast it works fine but I'd like to have what ever originally held the water in the tank
Posted on Jul 20, 2008
  • 1,673 Answers
If the seal and plungers are ok(bottom of tank), then most likely have a crack on the bottom of the tank, lot of times it will be under the seals, breaks away and will like out.
Posted on Jan 06, 2008
My Bissell proheat2x leaks water from bottom of machine, if you have the water tank full and cleaner and leave it sit it drains out onto the floor, it leaks when you are using it to, is this a seal or...
Nope, not a seal problem, just natural good old fashioned natural gravity. I know it doesn\'t take long for it to start leaking after use but Bissell covers this in the manual. Thoroughly clean the unit, run clean rinse water through every cycle and empty all tanks and cavities after use. Do not leave water in any of the tanks when not in use. What doesn\'t leak on your floor (which doesn\'t take long) could cause permanent blockages in the lines. It\'s a pain, I know, but I use the garage or back deck to park and prep mine after use.
Aug 15, 2013 | Vacuums
D4 Rainbow leaking water around the water basin while running. Already replaced the seal. Still leaking.
Clean the water separator. Use a tooth brush if you do not have the Rainbow separator cleaning brush. It is the same thing, and works perfectly. :-)
Dec 20, 2010 | Rainbow Technologies D4 Bagless Vacuum
Bissel Quicksteamer leaking
Hi there SmartAlec from here. I do a lot of work on the Vax range of machines (very similar) and 90% of the time it is the filters and/or the seals once they get a build up of shampoo on them they no longer seal properly but once removed and rinsed thoroughly they work again. Rinsing the machine through with clean water after a shampoo job will help this not happen again.
Hope this helps
Happy Vacuuming! :)
Aug 25, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning Solution leaks out around bottom
Most likely the opening under the seal has cracked or is starting to break away. You will have to replace the water bucket, the soap dispenser come with it, not separately.
Oct 20, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
532 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
