Question about HP LaserJet P2015 Printer
Long high pitched beep while printer is printing
2 Suggested Answers
SOURCE: high pitch noise
Try backing off on the screws that hold the fuser in place.Start with
the bottom right.
Posted on May 20, 2008
Wont start up and high pitch beep
The beeping is from the motherboard most likely. Sounds like you have some kind of virus. You may be able to access safe mode by holding alt+f4 when start-up but other then that I would take your PC in to get checked out.
Mar 20, 2015 | Computers & Internet
Sato cl408e - printing over perforations. I tried turning the Pitch(all the way to the right) and Offset(all the way to the left), and this helped a little, but still not right. Because of this, when the...
Reset printer sensor threshold setting.
Turn on printer whilst holding down line key untill printer beeps.
Use feed key to step to Gap in display.
Load label plus backing under sensor and not volts reading.
remove labels and place backing only under sensor and note volts reading.
use following formula
High reading + Low reading / 0.5 = Value to use
e.g 2.8 + 1.4 / 0.5 = 2.1.
use result to change value of input using line key once set press feed key to set.
To change label start position use the pitch menu.
Jun 02, 2011 | SATO CL408e Thermal Printer
Hp laser jet all leds on and not working
The surge protector or UPS may not be allowing sufficient voltage through to the printer. HP printers do not have built in speakers of any kind. Because of this, they are not capable of making any beeping or squealing sounds. If any noises such as these are heard then the printer is probably connected to an Uninterruptible Power Supply (UPS) or a backup battery. To verify that the UPS is the source of the noise, plug the printer directly into a wall outlet bypassing the UPS.
The following are common symptoms:
  • High pitched squealing, beeping sounds, or alarms (UPS)
    NOTE: Noise over the phone line can also cause high-pitched squeals and beeping sounds.
  • Inexplicable or false error messages
  • Printer will not "wake up" from sleep mode
  • Printer appears to be DOA
  • Incorrect printout
  • Slower than normal printing
  • The printer control panel display is blank or shows garbled characters
  • Accessories, such as attached copier/scanners, do not function properly
  • Monitor loses power or shuts off
  • Computer reboots when job is printing
  • Job only prints half way, causing a paper jam
If it is necessary for the product to be connected to the above-mentioned devices, consider the following items:
  • There are many UPS configurations and load conditions that can affect proper printer operation. Depending on these configurations or load conditions, printer functionality cannot be predicted.
  • No damage to current HP LaserJet products will occur, but, depending on their particular UPS configuration, the printer may or may not operate properly.
  • Printing while on a UPS battery backup is not recommended because of the large power requirements of HP LaserJet products.
  • If the HP LaserJet printer is not operating properly and power line conditions are suspected, try a different circuit (a different wall plug located away from the current one), or try removing it from the UPS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 24, 2010 | HP LaserJet P2015n Printer
Printer problem
Try replacing your laser unit. They are known to make a high pitch sound when they go bad.
Oct 29, 2008 | HP LaserJet 2200D Printer
My Laserjet 1018 will not start
HI,
Can you please describe your problem?
Jul 12, 2008 | HP Office Equipment & Supplies
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Beeps
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Jul 06, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
High pitch noise
Very bad. HP is crowd of fools, getting started to **** a brain to us.It was very good printer producer,now I dislike it more and more.
Dec 19, 2007 | HP LaserJet P3005 Printer
HP LaserJet P2015 Printer Logo
319 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
