Question about Canon MP830 All-In-One Printer
Error 6A00 - Canon MP830 All-In-One Printer
  • Canon Master
  • 17,970 Answers
Error 6A00 on Canon PIXMA MP 800
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. Usually I find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Comments from other users:
..my Pixma MP830 printer giving me a 6A00 error indicator. I solved my problem. Hope this will solve yours too. I moved the printer head over to the left. I noticed two black pieces of paper or sponges attaced to a spring on the right hand side where the head is at rest when not being used. I with a paper towel absorbed a little of the black in off the paper or sponge like material. I found the two white long pieces held by the spring were forward and would move. I used a ball point pen and moved the closed piece with the spring attached to the rear of the printer and it remained there. I surmised it was out of place because when I started up the printer again my 6A00 error code was gone and my printer was working again. It took me a long time to get to this point (like 6 hours) but that saved me from taking my printer in and spending like $80.00 or more for them to take care of the problem. Hope this helps you fix your Canon Pixma MP830 printer or other models giving the same error code to you.
END.
I hope help you woth this. Good luck.
Posted on Oct 07, 2009
6A00 error code
6A00 is a problem with the sheet feed unit. I would get in touch with Canon, to hopefully get it repaired. Not much you can do yourself sadly.
Nov 22, 2012 | Canon PIXMA MP830 All-In-One InkJet...
The copy shows a error code 6A00 I can't do anything with it the ink cradle does not light up
Solution Canon Pixma IP4300 Error 6A00, this reset tips is from someone in printer forum but the tutorial in picture. You can follow the instruction in the picture to solve error 6A00 in Canon iP4300. Some users say on the forum this reset method also work on Canon iP4200 and Canon MP800. Look the picture below to view the complete tutorial how to solve Error 6A00
Larger picture here
Jul 07, 2011 | Canon Office Equipment & Supplies
Error code 6A00
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All The Best: Pineworks
Apr 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
It says error 6a00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Feb 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MX850 ERROR CODE 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 05, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Jul 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
old marine
old marine
