Question about Hitachi M2 Digital Camera
NTSC to PAL question
PAL and NTSC are different. PAL is 25 fps, NTSC is 30 fps. So there is no way they can be compatible when you make it digital. There is also the resolution difference. NTSC has considerable fewer lines than PAL. MPEG is a better format, but you still have the frames-per-second diff. An MPEG camera :) My JVC S-VHS video will play both NTSC and PAL. But, if I want to view NTSC, I must be able to adjust the sync rate on my TV to make it do 60Hz. I HAVE 4 UNITS OF JVC SR-S365U SVHS MACHINES. THESE MACHINES ARE ALL NTSC AND I WOULD LIKE TO CHANGE THE SYSTEMS INTO PAL... IS IT POSSIBLE? HOW CAN I DO IN ORDER TO BE ABLE TO USE THESE MACHINES. I AM BASED IN KENYA AND WE USE PAL SYSTEM HERE IN KENYA? HOPE SOMEONE CAN HELP ME??
  • Timy Li
    Timy Li Dec 08, 2015
    Depending on where you live, DVD formats differ from each country. Generally speaking, a DVD disc released in a country which adopts NTSC television system couldn’t be recognized and played back by DVD player where the country adopts PAL television system. Unless the DVD disc is region free, most DVD players could only play back DVD discs released with the same television system. Here is a post that would introduce detailed information about NTSC and PAL, ways to play back NTSC and PAL DVD discs, and solutions to convert NTSC to PAL DVD and create PAL DVD disc out of videos:
    http://www.leawo.org/tutorial/ntsc-to-pa...
  • 1,113 Answers
There is only two ways I can think of depends on how you are wishing to use them
One way would be to use conversion software and the other would be to use a Converter and another converter link.
Sorry but I think your out of luck unless I'm seriously mistaken, Not possible is the answer. Below is general info on PAL / NTSC
Discs without codes will play on any player in any country but as the player will only output the video format of the disc, that disc may not be viewable on the television. For example, in the USA, the video format is NTSC and most televisions are NTSC only. If you were to try and play a PAL DVD from Europe on your newly programmed Region Free DVD player, it would also output a PAL video signal which the television could not show as NTSC and PAL are totally incompatible with each other.
Converting NTSC to PAL When converting from NTSC to PAL, two things need to be accomplished. 480 lines of resolution have to be upconverted to 576 lines of resolution, and 30 images per second have to be downconverted to 25 images per second.
The resolution upconversion does not actually add any real picture information to the image, as you cannot create real picture information where none existed before. It does, however, make the picture viewable on a PAL display, and often results in a superficially better-looking image. The frame rate conversion actually results in a loss of temporal resolution, as PAL has a lower frame rate than NTSC. Converting PAL to NTSC The converse situation applies to PAL to NTSC conversions. 576 lines of resolution are downconverted to 480 lines of resolution, and frames need to be inserted to go from the 25 frames per second of PAL to the 30 frames per second of NTSC. Once again, the resultant image is of less actual resolution than the original image, as information is discarded spatially and made up temporally.
Posted on Dec 24, 2007
  • Soulvisitor
    Soulvisitor Dec 24, 2007
    otacon's converter is way cheap option for you, good call I beleive, $30 bucks
    President:
  • 1,944 Answers
Why don't you just get an NTSC to PAL concverter (like this) that converts the signal to PAL. They are not expensive and doesn't require any modification of you machines.
  • 790 Answers
Yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
HI There I have an old camcorder the Model is a JVC GR-DVL 150E i have some very old footage on the camcorder tapes, i never ever got around to transfering the footage on to vhs video tapes! but now i...
You need to buy USB 2.0 Video Capture Adapter Card to do this action..
Pls visit the URL below as an example..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
EasyCap USB 2.0 Video Capture Adapter Card TV VHS DVD Capture high quality audio and video through your PC's USB port. Capture playback from VHS, Camcorders, TV, etc; capture audio without a sound card! Supports NTSC, PAL, Video format. NTSC: 720 x 480 @ 30 fps PAL: 720 x 576 @ 25 fps.
http://cgi.ebay.com/EasyCap-USB-2-0-Video-Capture-Adapter-Card-TV-VHS-DVD-/360339776240?pt=LH_DefaultDomain_0&hash=item53e5eca2f0
Jun 27, 2011 | Cameras
Hi There! I have an old camcorder, model is a JVC GR-DVL150E . I would like to know if its possible to transfer my footage from the tapes on to my PC and save it to discs! if so how do i do this and what...
Thanks
Jun 26, 2011 | JVC Video Cameras
I am using a Samsung model#SCA30 camcorder to playback my movies,to the easycap.My problem is that it will only playback in black&white,can I get color?
No . In the screen it will come on Black & white mode only. But when you make it in disk & play on CD player then it will come in color.
Jan 25, 2011 | Samsung Video Cameras
DVD player only plays in black and white on Soniq 42'' Plasma TV. (Have tried 3 different players all have the same problem)
The color loss is most likely due to a NTSC/PAL compatibility issue. If you bought the players overseas in a PAL region (http://upload.wikimedia.org/wikipedia/commons/0/0d/PAL-NTSC-SECAM.svg) and the TV is NTSC or vice-versa, there will be a color loss. Thiss because the different regions have different formats and when you go from one to the other, the color does no transfer over. You can buy a PAL to NTSC or NTSC to PAL converter to fix this issue.
Oct 06, 2009 | Televison & Video
I bought an HDTV LCD Sanyo from USA got it with me to Lebanon, when I turn the TV on the picture is so clear but it will not work on the satelite or caple, the picture not clear and has no voice. I need to...
There are currently 3 main television standards used throughout the world:
NTSC - National Television Standards Committee. The oldest existing standard, developed in the USA. First used in 1954. Consists of 525 horizontal lines of display and 60 vertical lines. Sometimes irreverently referred to as "Never Twice the Same Color." Only one type exists, known as NTSC M.
Here is a list of TV STANDAREDS I had for a while and can finally share it with someone. GOOD LUCK!!!! TECHMAN
SECAM - Système électronique pour Couleur avec Mémoire. Developed in France. First used in 1967. A 625-line vertical, 50-line horizontal display. Sometimes referred to by wags as "Something Essentially Contrary to the American Method" or SEcond Colour Always Magenta!" Different types use different video bandwidth and audio carrier specs. Types B and D usually used for VHF; types G, H, and K for UHF; types I, N, M, K1 and L for both VHF/UHF. Different types are generally not compatible.
PAL - Phase Alternating Line. Developed by German engineer Walter Bruch and the German electronic corporation Telefunken. Walter Bruch
patented his invention 1963 and the first commercial application of the PAL system was in August 1967. Also a 625/50-line display and variant of NTSC. Proponents call it "Perfection At Last." Due to the cost of the enormous circuit complexity, critics often refer to it as "Pay A Lot". Different types use different video bandwidth and audio carrier specs. Common types are B, G and H; less common types include D, I, K, N and M. The different types are generally not compatible.
Television Standards by Country
COUNTRY SIGNAL TYPE
AFGHANISTAN PAL B, SECAM B
ALBANIA
PAL B/G
ALGERIA
PAL B/G
ANGOLA PAL I
ANTARCTICA NTSC M
ANTIGUA & BARBUDA
NTSC M
ARGENTINA
PAL N
ARMENIA SECAM D/K
ARUBA
NTSC M
AUSTRALIA
PAL B/G
AUSTRIA
PAL B/G
AZERBAIJAN SECAM D/K
AZORES PAL B
BAHAMAS
NTSC M
BAHRAIN
PAL B/G
BANGLADESH
PAL B
BARBADOS
NTSC M
BELARUS SECAM D/K
BELGIUM
PAL B/H
BELGIUM (ARMED FORCES NETWORK) NTSC M
BELIZE
NTSC M
BENIN SECAM K
BERMUDA
NTSC M
BOLIVIA
NTSC M
BOSNIA/HERZEGOVINA
PAL B/H
BOTSWANA SECAM K, PAL I
BRAZIL
PAL M
BRITISH INDIAN OCEAN TERRITORY
(AF DIEGO GARCIA TV - AFRTS) NTSC M
BRUNEI DARUSSALAM
PAL B
BULGARIA
PAL
BURKINA FASO SECAM K
BURUNDI SECAM K
CAMBODIA
PAL B/G, NTSC M
CAMEROON PAL B/G
CANADA
NTSC M
CANARY ISLANDS
PAL B/G
CENTRAL AFRICAN REPUBLIC SECAM K
CHAD SECAM D
CHILE
NTSC M
CHINA (PEOPLE'S REPUBLIC)
PAL D
COLOMBIA
NTSC M
CONGO (PEOPLE'S REPUBLIC) SECAM K
CONGO, DEM. REP. (ZAIRE)
SECAM K
COOK ISLANDS PAL B
COSTA RICA
NTSC M
COTE D'IVOIRE (IVORY COAST) SECAM K/D
CROATIA
PAL B/H
CUBA
NTSC M
CYPRUS
PAL B/G
CZECH REPUBLIC
PAL B/G (cable), PAL D/K (broadcast)
DENMARK
PAL B/G
DIEGO GARCIA NTSC M
DJIBOUTI SECAM K
DOMINICA
NTSC M
DOMINICAN REPUBLIC
NTSC M
EAST TIMOR
PAL B
EASTER ISLAND PAL B
ECUADOR
NTSC M
EGYPT
PAL B/G, SECAM B/G
EL SALVADOR
NTSC M
EQUITORIAL GUINEA SECAM B
ESTONIA PAL B/G
ETHIOPIA PAL B
FALKLAND ISLANDS (LAS MALVINAS) PAL I
FIJI NTSC M
FINLAND
PAL B/G
FRANCE
SECAM L
FRANCE (FRENCH FORCES TV) SECAM G
GABON SECAM K
GALAPAGOS ISLANDS NTSC M
GAMBIA PAL B
GEORGIA SECAM D/K
GERMANY
PAL B/G
GERMANY (ARMED FORCES TV GERMANY) NTSC M
GHANA
PAL B/G
GIBRALTAR
PAL B/G
GREECE
PAL B/G
GREENLAND
PAL B
GRENADA
NTSC M
GUAM
NTSC M
GUADELOUPE SECAM K
GUATEMALA
NTSC M
GUIANA (FRENCH) SECAM K
GUINEA PAL K
GUYANA NTSC M
HAITI
SECAM
HONDURAS
NTSC M
HONG KONG
PAL I
HUNGARY
PAL K/K
ICELAND
PAL B/G
INDIA
PAL B
INDONESIA
PAL B
IRAN
PAL B/G
IRAQ
PAL
IRELAND, REPUBLIC OF
PAL I
ISLE OF MAN
PAL
ISRAEL
PAL B/G
ITALY
PAL B/G
JAMAICA
NTSC M
JAPAN
NTSC M
JOHNSTONE ISLAND NTSC M
JORDAN
PAL B/G
KAZAKHSTAN SECAM D/K
KENYA
PAL B/G
KOREA (NORTH)
SECAM D, PAL D/K
KOREA (SOUTH)
NTSC M
KUWAIT
PAL B/G
KYRGYZ REPUBLIC SECAM D/K
LAOS PAL B
LATVIA PAL B/G, SECAM D/K
LEBANON
PAL B/G
LESOTHO PAL K
LIBERIA
PAL B/H
LIBYA
PAL B/G
LIECHTENSTEIN
PAL B/G
LITHUANIA PAL B/G, SECAM D/K
LUXEMBOURG
PAL B/G, SECAM L
MACAU PAL I
MACEDONIA PAL B/H
MADAGASCAR SECAM K
MADEIRA PAL B
MALAYSIA
PAL B
MALDIVES PAL B
MALI SECAM K
MALTA
PAL B
MARSHALL ISLANDS NTSC M
MARTINIQUE
SECAM K
MAURITANIA SECAM B
MAURITIUS
SECAM B
MAYOTTE SECAM K
MEXICO
NTSC M
MICRONESIA
NTSC M
MIDWAY ISLAND NTSC M
MOLDOVA (MOLDAVIA) SECAM D/K
MONACO
SECAM L, PAL G
MONGOLIA SECAM D
MONTSERRAT NTSC M
MOROCCO
SECAM B
MOZAMBIQUE PAL B
MYANMAR (BURMA)
NTSC M
NAMIBIA PAL I
NEPAL B
NETHERLANDS
PAL B/G
NETHERLANDS (ARMED FORCES NETWORK) NTSC M
NETHERLANDS ANTILLES NTSC M
NEW CALEDONIA SECAM K
NEW ZEALAND
PAL B/G
NICARAGUA
NTSC M
NIGER SECAM K
NIGERIA
PAL B/G
NORFOLK ISLAND PAL B
NORTH MARIANA ISLANDS NTSC M
NORWAY
PAL B/G
OMAN
PAL B/G
PAKISTAN
PAL B
PALAU NTSC M
PANAMA
NTSC M
PAPUA NEW GUINEA PAL B/G
PARAGUAY PAL N
PERU
NTSC M
PHILIPPINES
NTSC M
POLAND
PAL D/K
POLYNESIA (FRENCH) SECAM K
PORTUGAL
PAL B/G
PUERTO RICO
NTSC M
QATAR
PAL B
REUNION SECAM K
ROMANIA
PAL D/G
RUSSIA
SECAM D/K
ST. KITTS & NEVIS
NTSC M
ST. LUCIA
NTSC M
ST. PIERRE ET MIQUELON SECAM K
ST. VINCENT
NTSC M
SAO TOMé E PRINCIPE PAL B/G
SAMOA, AMERICAN
NTSC
SAUDI ARABIA
SECAM B/G, PAL B
SAMOA NTSC M
SENEGAL
SECAM K
SEYCHELLES PAL B/G
SIERRA LEONE
PAL B/G
SINGAPORE
PAL B/G
SLOVAKIA PAL B/G
SLOVENIA PAL B/H
SOMALIA PAL B/G
SOUTH AFRICA
PAL I
SPAIN
PAL B/G
SRI LANKA PAL
SUDAN
PAL B
SURINAME
NTSC M
SWAZILAND PAL B/G
SWEDEN
PAL B/G
SWITZERLAND
PAL B/G
SYRIA SECAM B, PAL G
TAHITI
SECAM
TAIWAN
NTSC
TAJIKISTAN SECAM D/K
TANZANIA
PAL B
THAILAND
PAL B/M
TOGO
SECAM K
TRINIDAD & TOBAGO
NTSC M
TUNISIA
SECAM B/G
TURKEY
PAL B
TURKMENISTAN SECAM D/K
TURKS & CAICOS ISLANDS NTSC M
UGANDA
PAL B/G
UKRAINE
SECAM D/K
URUGUAY PAL N
UNITED ARAB EMIRATES
PAL B/G
UNITED STATES
NTSC M
UNITED KINGDOM
PAL I
UZBEKISTAN SECAM D/K
VENEZUELA
NTSC M
VIETNAM
NTSC M,SECAM D
VIRGIN ISLANDS (US & BRITISH)
NTSC M
WALLIS & FUTUNA SECAM K
YEMEN
PAL B/NTSC M
YUGOSLAVIA PAL B/G
ZAMBIA
PAL B/G
ZIMBABWE
PAL B/G
Sep 06, 2009 | Televison & Video
Tv format conflict warning message
I think the reason for this is if you record at a framerate > 25-30 fps (in fraps for example). Try it with a video recorded at 30fps, it should work.
Apr 06, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
KX-GA3TV will not hold picture on vertical plane (English stations and reversing PAL cctv camera)How do I adjust from US to PAL?
Extremely sorry about the chat session... We're having some connection problems.. ANyways your device is not Compatible with PAL input. Its NTSC only(US). However there is a work around. You can get the PAL to NTSC converter(costs around 30$) that will enable you to play PAL on your Device.
http://sewelldirect.com/mayflash-pal-to-ntsc-converter.asp
Also I can help you find the maps for it if you need them..
Regards,
Sai.
Oct 03, 2008 | Panasonic Televison & Video
Problem with Sony Hi8 ntsc playback
Do you have firewire ( IEEE 1394 } input on your computer if you do. You can transfer direct from your CAM to computer or burn into DVD without using Dazzle 150 see how to do it in user manual if you have not user maual, download from Sony Web
Let me know if you need further assistant
Cheers
Aug 27, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Hi8 to Computer for editing
Color: Black Part No.USBG-VX3 VISTA COMPATIBLE USB Video Adapter USB 2.0 Audio/Video Grabber S-video& Composite
AUDIO AND VIDEO GRABBER FOR WINDOWS VISTA GrabBee X+ USB 2.0 Audio/Video Grabber New Generation USB2.0 Audio/Video grabber is the best ideal companion for your portable audio/video application. Real-time MPEG 1/2/4 recording make you have powerful video application on hand. GrabBeeX+ USB 2.0 A/V Grabber is the bridge between your computer and analog camera, VCR, camcorder or other video source. GrabBeeX+ USB 2.0 Video Grabber is small enough to fit in the palm of your hand and is ideal for both notebook and desktop computers. Applications : Video recording & editing Take photo Video email Security monitoring system Features : Small Wonder--Dimensions are (L)81mm x (W)30mm x (H)15mm Audio and video go though USB 2.0 bus (WinXP) to make best performance High speed USB 2.0 data transfer rate for best video recording Encoding MPEG 1 or MPEG 2 format directly use InstantMPEG Technology, Ideal formats for creating VCD or DVD movies Up to 25 fps motion capture capability at 720x576(PAL) & 30 fps at 720x480(NTSC) SnapShot function support Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Recording period setup Composite, S-Video analog input, NTSC, PAL and SECAM multi system support Support Brightness, Contrast, Hue, Saturation, Sharpness control Powerful video editing function include Motion Video Special Effects/ Title Effects/ Picture-in- Picture Effects/ Slow & ast Motion Video Effects/ background music/?color background/ Transitional Effects Plug & Play Low power consumption. Ideal for portable computer too No Battery---No need to install batteries or run off the wall adapter
  • Specifications : Video input : One RCA composite, One S-Video.
  • Video system : NTSC, PAL and SECAM multi system support Audio input : in WinXP, go through USB; in Win2000, go through sound card
  • Motion capture : AVI format from 160x120 to 720x576 resolution MPG format from 320x240 to 720x576 resolution Still image capture : BMP/JPG/TIF/PCX/TGA file format
  • Performance : Up to 25 fps at 720x576 for PAL, 30fps at 720x480 for NTSC Power Source : 5VDC,300mA(max) through USB port Minimum System
  • Requirements : USB 2.0 equipped computer Pentium 4 1G or above 128MB of RAM Windows 2000/XP Sound card
  • Package Contents :
  • GrabBeeX+ USB 2.0 Audio/Video Grabber
  • GrabBeeX+ drivers CD
  • Ulead VideoStudio editing software
  • User's manual
    I have heard this works, going to try one today, I have tried EVERYTHING else, downloading drivers, diffferent programs, firewire cords, so I think this will work, when I googled our specific camcorder, this matches, also, some people are selling the exact sony camcorder on ebay with this included, stating they have used it to connect to their pc. Hope this helps.
  • May 06, 2008 | Sony Handycam CCD-TRV608 Camcorder
    Playback of discs
    Have you tried setting the players video output to your TV type?
    R1 discs are NTSC(30 fps), while R2 are PAL(25 fps). Look for video output or TV type in the player's menu. Most player's default to "any", passing whatever signal is on the disc to the TV.
    Dec 19, 2007 | Panasonic DMR-ES10 DVD Recorder
    Hitachi M2 Digital Camera Logo
    250 people viewed this question
    Top Hitachi Cameras Experts
    Parshiv Luthra
    Marvin
    Marvin
    Are you a Hitachi Camera Expert? Answer questions, earn points and help others
