Question about Dryers
Maytag LDE512 wont dry clothes, and the drum does move the clothes around.
  • 80 Answers
Sounds like a thermal fuse problem!
whens the last time you had the vent cleaned
this failure’s usually not the thermal fuse’s fault, but the real cause lies in a partially (or completely) clogged dryer vent system. In those cases, the thermal fuse is just doing the job it was designed for.
Posted on Oct 07, 2009
  • Johnny
    Johnny Oct 07, 2009
    didnt realise you have a maytag...scratch that!!!
Have a maytag heavy duty dryer model lde512 07 series and it is not getting clothes all the way dry what could be wrong
Problem might be with your washer not spinning them dry enough..or your vent is plugged up with lint
May 06, 2017 | Maytag Dryers
Drum rotating unevenly, squeaking
If the drum moves up/down side/side without the outer drum moving, bearings gone, replace. To check for clothing, which I doubt, remove front seal outer section, look around outer part, to bottom you probably find clip, prise apart, front back, not side ways, refit sideways
Mar 16, 2013 | Maytag MAH2400A Front Load Washer
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
The drum will not move, so my clothes of course will not get dried. HELP !!
the belt, pulley or motor, here is a website that will assist you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 02, 2011 | Maytag PYE2300AY Electric Dryer
We have a Maytag Electric Dryer, Model LDE512 , which leaves black marks on clothes while drying them. The dryer is about 18 yrs. old and has been working great except for this one problem. We have...
HI The drum is mostly stainless steel; The end that contacts the drum guide is just painted steel. After years of rubbing, some rust can form after the paint wears away,thus, causing the stain. Painting the bare metal (after removing all rust) and replacing the tumbler bearings,roller and roller shafts, will correct this issue and prevent it form happening in the future. You should also replace the tumbler seal while the unit is disassembled. Part numbers are below:
Tumbler bearings/Glides(You need two)- 306508
Roller - 12001541
Roller shaft - 6-3129480
Tumbler seal - 314820
Roller Shaft washer - 312535
Retaining Ring(shaft)- 410233
Jul 16, 2010 | Dryers
Maytag pavt244aww
We had the same problem and it is a known problem by Maytag. They came and replaced the springs under the drum as the original ones were not stong enough.
Dec 10, 2009 | Maytag Washing Machines
Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Feb 01, 2008 | Dryers
Dryers Logo
120 people viewed this question
Top Dryers Experts
