I have a hotpoint aquarius wma 30 washing machine, when i put a wash on water pours out the door and floods my kitchen does anyone have an idea what could be causing this? thanks
    President:
  • 1,304 Answers
As a service tech in your home the first thing i would ispect is the pressure tube and switch, this is what controls the level of water in your machine
the end of the tube may be clogged,
or a small leak in it,
or the pressure switch might be stuck
Posted on Oct 10, 2009
There is water leaking from the bottom of the door of our Hotpoint Aquarius WMA 56 washing machine. What could be the cause.
Have you been wiping the glass off in the door. A buildup of detergent crust on the bottom will cause the seal to weep.
Jul 20, 2012 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Washing machine keeps flooding kitchen
For the age of it, you can either replace it or get it fixed. I would personally get a quote first for repair.
May 18, 2012 | Hotpoint Aquarius WT540 Front
Hotpoint Aquarius Extra WMA40 - Prewash light flashing and cycle not completing? The water level also looks to be very high? As tenants this machine has been installed (we suspect second hand) to replace a...
The water level on the Hotpoint WMA range of machine should be below the door, check out the error code definition at this site. You probably have a pressure chamber blockage or partial blockage. There are also workshop manuals for the Hotpoint WMA & WM machines which run through this sort of repair.
Mar 20, 2010 | Hotpoint WMA40 Front Load Washer
WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Washing Machines
Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Spin leak
The filter is located at the back of the machine.
Jan 01, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
