I have 2 computers one of them is not working correctly i bellive their is a problem with the motherboard it wont display an image or any sound i have all my pictures and music and programs that i dont have on my newcomputer can i some how make the hardrive work on my new computer witout losing any of the data
  • 2 more comments
  • ajbad4ever Oct 07, 2009
    ok i have removed the hardrive i see the diagram but i see no extra jumper wire in my new pc i have the extra one but i see no extra slot were to plug it in
  • 416 Answers
Of course....simply remove the hard drive from the computer thats experiencing problems. Look where the HDD interfaces to the system and you will see 8 pins (2 rows of 4) with a black plastic connector on two of the pins. This is called a "jumper" on the HDD it will have a diagram by these pins showing how to position the jumper for different configurations.......use configuration "slave" and then install the HDD in your new computer. When windows loads it will recognize the HDD from your old system as an additional drive and allow you to access any and all files on that drive. GOOD LUCK AND PLS RATE THIS POST!!!! :D
Posted on Oct 07, 2009
  • Remote Computer Rescue
    if you dont have a jumper to setup the HDD, then you may have to get one from a computer store.....go to a local store and they will probably give you one, they are very inexpensive.........as for plugging it in, the cable that is plugged into the hdd on the new system should have an extra place to plug it into......dont worry, as long as the HDD is connected it will work, there is no real order for these, also, make sure you supply power to the HDD via one of the extra power connectors under your hood. remember, make sure your new HDD is set to "master" and the old one is "slave":
K8NF4G MOTHERBOARD IS NOT WORKING
Your Video Card (Graphics Card) is probably bad. To isolate the problem connect another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays the same NO Signal Message then your video card is bad. If the Borrowed monitor displays and works correctly, then your original monitor is bad. The fact that your monitor displays the No Signal Message on it shows that the monitor is ok.
If you have a laptop, the video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 30, 2012 | Asrock K8NF4G-SATA2 Motherboard
System freezes-Video display=multi-staggered image(not legible)
It's either a loose connection from the motherboard to the video-display, or a partially-broken video-display, or the video-adapter in your motherboard.
Connect an external monitor -- if it looks OK when the internal LCD is "wavy", then your computer is fine.
But, since your say "happens to both screens", the most-likely problem is the video-adapter, which usually means that you will have to get COMPAQ to replace the motherboard.
May 26, 2010 | Computers & Internet
No display asrock k10n78 am2+
Try to reset the bios!
Are there any sounds?
if the motherboard is new use the manual to see how to reset the bios.
Should be a jumper you have to move or just unplung the battery make a short between the contacts from the battery socket for at least 10 seconds . !!! Unplung the Main power First!!!.
See if it works now.
Jan 09, 2010 | Asrock Skt-am2+ K10n Motherboard
I plug these speakers into rear of pc with correct color but they wont install/work. Also they are not listed as a device under the sounds and devises in the control panal
You need to install the audio driver for your computer's motherboard in order for your speaker to work. Use your motherboard support disc to install the driver.
Dec 23, 2009 | Dell A215 Computer Speakers
I have just a new computer and when I turned on for the first time, it power up but no image on the monitor, I have checked the connection and tested the monitor on laptop and it works, it conclude that...
first check u ram seated correctly or not and verify u hear the boot sound or not.disconnect all ur connection to the motherboard and reconnect finally then check it
Nov 04, 2009 | Intel D945GCCR Motherboard
Hello. This computer will recognize a good
This is the problem with the display capacitor on your motherboard. Try replacing the display capacitor by good technician. If it doesnt solve your problem you need to change the motherboard. But mostly this will solve your problem.
Oct 15, 2009 | HP (D9820-60007) Motherboard
The conp start up but the screen is blank
good day, there are several reasons why the pc wont display images on screen, you may have to reseat your memory module. check also other expansion cards that needs to be reseated. do this several times until the pc boots. if not i need additional info. hope this helps.
Jul 19, 2009 | Intel D865GBF Motherboard
Image wont display even with right click
Sounds like you may have the screen enlarged. Press your F11 button. It will maximize or minimize your screen (depending on what position it happens to be in at the moment). Let me know how that works for you. If it did, please rate my answer!
Feb 11, 2009 | Cornerstone FIC AD11 Socket A ATX...
No display
try a video card and turn off the onboard display card.
Dec 04, 2007 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Computers & Internet Logo
David Payne
David Payne
