Question about Gaggenau Ovens
Gaggenau oven model eb 180610 self cleaning cycle does not clean. The unit turns on, runs and seems to produce heat out of the vent. Note - located at 8500 foot altitude.
ctf1800
  • 4402 Answers
SOURCE: oven
go here
http://www.gaggenau.com/AE_en/Home.do
the customer support
then operation manual
Posted on Dec 04, 2007
  • 12 Answers
SOURCE: Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Posted on Sep 01, 2008
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
jumptrout51
  • 3361 Answers
SOURCE: My KitchenAid Supra self cleaning convection wall
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Posted on Feb 28, 2009
  • 10 Answers
SOURCE: error code F 20 on Gaggenau EB 260/262 oven
Sometimes the error light will come on because of mixed signals sent. If everything works, then just ignore it. Unplug the oven or turn power off in fuse box. This may reset the light control. Be very careful around the power source. Wear rubber bottom shoes, have dry hands and floor. Don't touch exposed wires with anything. This is 240 volts that can hurt or kill you!!!!!!
Posted on Nov 03, 2009
Testimonial: "Appreciate the advise, but would still like to know the exact meaning of error code F 20. Thanks."
I have a Gaggenau 270-271 wall oven. It is showing F 42 on the screen. what does this mean?
Open circuit in the door contact switch even if the door is locked.
If this happened during a clean cycle sometimes if you start another cycle and then switch the selector off after a few seconds the fault will right itself. If this doesn't work then you probable need a new door lock.
Hope this helps
Jun 11, 2010 | Gaggenau EB 270/271 Electric Single Oven
I have a Gaggenau E-378-6 that will not heat, yet I can't find a manual with parts
Hi, I think the model should be EB786, but aside from that I have a question, does this problem follow a self clean cycle ? If so it is very likely the hi-limit safety/cut out that has been tripped ( assuming you've checked the 40amp breaker and set the clock ). I'll wait for your reply re; self clean cycle. Macmarkus :)
Apr 01, 2010 | Gaggenau EB290 Electric Single Oven
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Door locked after power surge/failure
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
Jan 06, 2008 | Gaggenau EB270 Electric Single Oven
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau EB294/295 Electric Double Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Nov 20, 2007 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
44 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
