Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
How can i do a Lacie backup of only what i have new on my hard drive? when i open the backup function, it wants to start from the beginning, taking hours
    Sergeant:
  • 361 Answers
I am using now pocket hd 320gb. of black bery. there was a softwere but not necessary to use it
hdd n pendrive r similar to use
so u no need software to use hdd i think there is a problem in your hdd .
Posted on Oct 09, 2009
  • 739 Answers
It depends on the back-up software.
Some will let you specify what you want backing up and some don't.
However, is it such a bad thing that it starts from the beginning? Unless it does it every single time (which would suggest that something is wrong with the settings) it should only do a complete back up the first time. Each subsequent BU should only involve files that have changed since the previous BU.
If you cannot control what gets backed up then you can always do it manually - the way we did it before cheap HDs and BU software.
Posted on Oct 07, 2009
I have a Lacie wireless space network drive (1TB) connected directly to my router. I'm only using the switch functionality and have my pc connected to the internet through one of the 3 ports on the...
Here is what LaCie suggests about this issue:- first backup any data you have copied on Wireless Space. You can also backup your configuration: from "configuration" tab of "Support" widget, click "save" button next to "Configuration file", it will download a backup file.
- still in "configuration" tab of "Support" widget, tick the third box labeled "Restore device to factory state (data erased)", or any equivalent quote in selected language, and click apply
- the device will reboot, rebuild hard drive image, then reboot on default state. The issue is definitively fixed
- it is recommended to apply latest update downloaded from LaCie website
- you can restore previous configuration in "configuration" tab of "Support" widget, click restore and select previously downloaded backup file
Feb 07, 2011 | LaCie Wireless Space 2TB Wireless Storage...
My lacie hard drive fell a few minutes ago. It now takes a really long time to load up and open files. It also keeps making a clicking sound what could be the problem and whats the solution
It sounds like you have damaged the drive.
The clicking sound is a mechanical failure where the the read arm inside the drive is hitting the magnetic platters. You should backup your data immediately as drive failure is imminent.
Robert from Blitware
Jun 25, 2010 | LaCie (300728U) 250 GB Hard Drive
Freezes up During Backups
I suggest an application called "Disk Warrior" it has always maintained high ratings among us Mac enthusiasts it has a hardware test function built into it and seems to be a little better at verify and repair functions than Disk Utilities which you can try also if you haven't yet. You may also consider trying a different firewire cable if you have one handy. Other than that a reformat should have put the disk back into an original state however the disk could have been damaged by not un-mounting it in rare mac cases. If you have the time you can also reformat the disk again although I would try the first two options first.
Apr 23, 2009 | Computers & Internet
LaCie 200GB HD is now ''read-only''. Recommends reformatting.
>> my computer could not repair the hard drive
It seems that the disk-drive is "dying", and the "table of contents" on the hard-drive has become corrupted, and automated attempts to "repair" the corruption have failed.
>> the hd is being offered with limited functionality, basically read-only.
Yes. Take this as a "hint" that the disk-drive is about to "die".
>> It recommends that I back-up the info elsewhere
Good advice. Take the advice.
>> and reformat.
This may help -- it will identify any "bad" spots on the hard-drive, and will either permanently avoid using those bad spots, or it will allocate a "spare" track on the drive to be used as a substitute for the "bad" area.
However, even after doing this, I would not "trust" the device to be a "reliable" backup for my important files. Like a well-used chalk-board in a classroom, the disk is getting "worn-out".
If it's still under warranty, exercise the warranty.
If the warranty has expired, replace it.
Apr 22, 2009 | LaCie Computers & Internet
"The disk LaCie was not repairable by this computer. It is being made available to you with limited functionality. You must back up your data and reformat the **** as soon as possible. Am using it as
Bob,
I had a similar problem with two LaCie external hard drives.
LaCie doesn't manufacture hard drives, they only purchase drives from other companies, like Seagate, and mount those drives in LaCie external enclosures.
If the drive is nearing the point of total failure, then your Mac is letting you know that point is very close. You had better find a new backup device to use. The Mac will let you access the drive for a while longer, but if you do not act, there will come a point when the Mac will not be able to read the data on the drive and any backups you have there will be lost.
When you get a new external hard drive to use for backup, you may not need to do anything with the current drive that is failing, as long as you do not anticipate that you will need anything from the backups that it contains. You can set up the new device as your primary backup. I would then advise that you perform a total backup on the new device ASAP, so that you are not left without at least one good backup.
Sep 27, 2017 | LaCie (300740) 160 GB Hard Drive
Lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
My LaCIe external hard drive will not open - I get a message saying that the disc is not ready and there may be a drawer open as though it is a DVD ROM - I have tried it on 3 diff computers and the message...
I am not really sure where to start here because I am a little confused about your setup here. It seems you made a great choice to keep Windows and your data on separate drives. Your primary hard drive is a really fast SATA Raptor drive, which is great, but I would never use an external hard drive for general everyday data storage. Many will probably disagree with what I have to say, but external hard drives should really be used only for temporary backup. I would never suggest using an external hard drive as your only copy of your data or for regular everyday use. There are several reasons for this:
1. External Hard drives are generally slower than Internal Drives.
2. Many of them come preformatted with Fat32, so you are limited to files no larger then 4gig.
3. They are more likely to fail because they are normally subjected to a greater likelihood of accidental bumping or dropping.
4. Many external drive enclosures are not properly cooled for continuous usage and thus lead to premature failure.
5. You often have no idea what brand of hard drive is actually inside the enclosure.
Don’t get me wrong, external hard drives are wonderful and I use them all the time. I have three LaCie 160 gig drives myself that I use all the time for temporary backup, but I rotate them so that I have 3 consecutive backups and would never use them (not just Lacie but any external drive) as my only backup or as a primary data drive. And yes, I have had to replace a few of them due to failure.
So to address your specific questions:
What went wrong?
1. Bad Cable - Well it is probably unlikely, but I would first try another USB cable just to make sure the cable is not damaged.
2. Power Supply - Try another power supply if you have or can borrow one.
3. Controller Failed – The Controller inside the Lacie has failed.
4. Drive Failure – The Hard Disk inside the Lacie has failed. Drives typically have an average 5 year lifespan, some last longer and some can fail much sooner. Unfortunately, you rarely have any warning, thus the need for backups.
Nov 05, 2008 | LaCie Computers & Internet
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
75 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
