Question about JVC KD-G120 CD Player
My cental display does not work , i have a kdc-7544u head unit
I have a Peugeot 206 gti and have got no display as mentioned is their an adapter i can buy to get this to work.
    Genius:
  • 1,098 Answers
Hi
Im not sure if there is an adapter but you should be able to wire it up to the ignition live wire from the stereo this is the memory wire also on some radios. I belive the wire is yellow but you will have to double check the wiring diagram. a single wire should do it as long as the display has it's own earth.
Posted on Feb 01, 2010
My heater in my peugeot 206 gti is on constantly..tried changing the climate control unit but it has made no difference...any ideas?. thanks :)
According to the Peugeot dealer the 206 gti thermostat resistor is embedded in the heater blower fan, so the blower fan must be replaced ( Supplied VIN # for confirmation). However the how to remove the blower is the subject of many discussions on every 206 site. Some say turn blower clock wise, anti clock wise, remove hex screw, don't remove screw. So I am still waiting for a sure answer, I picked up a blower (second hand) but the old blower wont budge, clock or anti , someone suggested to try brute force like with a hammer, I am not game to do that, but I may have to.
Jul 11, 2012 | Cars & Trucks
I have a peugeot 206 gti the clutch has gone but the car wont start now i was told it had a safety thing on it to stop it starting until its fixed is this right and how can i over ride it?
i have been fixing peugeots for 12 years and never heard anything like that.
it is mrer then likley a faulty crank position sensor, coil pack or quite simply the fuel cut off switch needs resetting which should be located under the bonnet on the n/s (black unit with a red rubber top) just press the top and try starting the car..
if this helps let me know
cheers
big mike
Mar 06, 2010 | 2005 Peugeot 405
Ive got coolant water coming out as fast as i put in my 206 gti
Freeze plug, head gasket, hose to the heater core. You have to get back there and look.
Feb 06, 2010 | 2005 Peugeot 405
Cylinder head bolt torqe settings on peugeot 206 gti
bolt length 147mm. stage 1, 15nm, stage 2,50nm, 3 slacken off 360 degree, 4 tighten 20nm,5,285 nm, hope this helps, ive checked this on auto data so settings are correct, do it in 5 stages starting from centre and working in a clockwize direction.
Nov 29, 2009 | 2005 Peugeot 405
I have a 2001 206 gti and the engine just died
hiya mate if you have got a live at the fuel pump when engine is turning over then your relay is working.
you could possably have a fauly crank position sensor (which can be checked using a code reader) which would stop the engine from starting, also check the fuel pressure switch has not been activated (this is located on the n/s/f inner wing and is a small black unit with a red cap on it)
it would also be a good idea to make sure the timing belt has not snapped.
Sep 29, 2009 | Peugeot Liberte Cars & Trucks
Peugeot 206 GTi (Engine Squeeking Noise)
IF THIS IS NOT A SURPENTINE BELT,TRY THE P/S BELT TO SEE IF ITS LOOSE
Aug 20, 2009 | Peugeot 405 Cars & Trucks
Peugeot 206 2001 GTI
Check the alternator belt for proper tension. Also check alternator voltage output. If output is low the rest of the systems can fail.
Jul 05, 2008 | Peugeot 405 Cars & Trucks
JVC KD-G120 CD Player Logo
466 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
