Samsung front load washer Mod# WF337AAR/XAA Do you know the part # for the Hall sensor and motor?
  • Jerry Kerns Oct 08, 2009
    Samsung
    MOD# WF337AAR/XAA
    Serial# 348654AQ300515D
    1 1/2 yrs. old
    President:
  • Washing Mach... Master
  • 1,723 Answers
Could you recheck the model number? That model is not coming up??
Posted on Oct 07, 2009
  • Craig Butler
    Craig Butler Oct 08, 2009
    Still looking, I can't find much for Samsung. It seems that they are affiliated with Whirlpool...
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
What does le mean when washer does not work
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jun 19, 2011 | LG WM-2277HW Front Load Washer
I have washer machine wm2277hw LG., Tromm., this machine have flash light "" LE"" Error, what is the problem?
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
May 22, 2011 | LG WM-2277HW Front Load Washer
Samsung washer wf218anb/xaa has code dc and wont spin clothes they are still wet
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
Mar 03, 2010 | Samsung WF337AA Front Load Washer
Samsung front load washer keeps getting E7 and E3 what is this?
E3 - MICOM is attempting to drive the motor but is not getting any
response signals from the hall sensor. Visual check shows
motor is not running. (Locked, Defective Hall Sensor or
Overload)
Im not locating an E7 error. Did you mean 7E?
This information may or may not relate to your washer since you did not provide a model number.
Nov 25, 2009 | Samsung Washing Machines
EnerGuide Rating?
Here is energy guide for your washer machine
Mar 04, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
