Question about Kodak EasyShare Z7590 Digital Camera
Does not alway start up - Kodak EasyShare Z7590 Digital Camera
2002 Accent doesn't always start. The battary is
check battery voltage,check all leads are clean
Jan 01, 2010 | 2002 Hyundai Accent
1991 firebird turns over slow,but always starts.
If the battery is in good condition, good connections and passes a load test, the starter may be bad. But be sure the connections and the grounds are good.
Dec 30, 2009 | 1991 Pontiac Firebird
94 LuminaAPV wont start --Sometimes
When you replaced the ECM, did you use a nice coating of di-electric grease? That helps distribute the heat from the ecm so it doesn't over heat. Also check your ignition wiring going from the battery to the ignition switch. Check for any loose or broken connections. A local shop can help you find wire shorts BUT BE ADVISED, Most shops charge a $70 an hour fee to diagnose electric problems. Thats not to fix, only find problems. I highly recommend a self search first.
Jul 08, 2009 | 1994 Chevrolet Lumina APV
Car always turns over but does not always start with first turn of the key but then always starts with second turn of the key?
Try changing the fuel filter.
When you turn the key it activate the fuel pump. Gas is then pump to the engine to start.
If you see no improvement then try some thing to clean the gas tank. ( gum out)
Mar 10, 2009 | 2001 Pontiac Grand Am SE
1991 Metro does not always start.
the safety switch under the clutch pedal is sticking.
Jan 23, 2009 | 1991 Geo Metro
Electrical problem?
ALWAYS ALWAYS ALWAYS start your diagnosis by getting the trouble codes read. Period.
Aug 27, 2017 | 1998 Subaru Forester
Kodak EasyShare Z7590 Digital Camera Logo
15 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
