After turning on, it has error code: E000020-0360 then says turn off and back on again. I do that and still get same code and will not go any further.
  • markmatta Feb 08, 2010
    This is a Canon Imagerunner C3200
  • bulldogchief
    bulldogchief May 11, 2010
    What make and model copier do you have? Just giving an error code doesn't help.
  • 168 Answers
If this is a color copier 3220/3200 its your magenta drum the one next to the black drum
Posted on Oct 09, 2009
Laser scanner unit error. Turn off the printer,then contact the store you purchased the printer inform them of the error code displayed and symptoms. Error Code: E100 0000
that is what you should be doing as it is a warranty repair problem, not contacting fixya because you have a direction of what to do
Sep 19, 2016 | Canon LBP3300
Printer error. Turn off the printer, and then
So, if you followed the procedure you describe the printer should be working again. Or is it?
Nov 02, 2013 | Canon LASER SHOT LBP-2900 Printer
Error Code: E100 0000 Printer error. Turn off the printer, and then turn it back on again after a moment. If the same error occurs, turn off the printer, then contact the store where you purchased th
It is possible a reboot may correct the issue, but current indications are the error indicates a bricked console. You may go back through the retailer you purchased the console from in order to quickly receive a new console right away rather than going through Microsoft, which will repair the console over the course of a few weeks. This is the recommended course of action, though not the only one, as Microsoft's return times do promise to be hastened.
For more help visit cbrtechsolutions
Feb 02, 2013 | Canon LBP6000 Laser Printer
http://fix-your-printer.blogspot.in/2009/03/canon-lbp2900-error-code-e100-0000.html
Error code E#100, ERR 100 or E100-0000 is a laser scanner unit error.
Solution 1:
Turn off the printer, wait 10 minutes, and then turn it on again.
Solution 2:
Flip open the top of the printer.
Look for a small shutter that holds the laser: carefully force this open with your hands and force the laser out into the center of the tracking cradle.
After you move the laser, unplug the printer for a few minutes.
Plug the printer back in.
Solution 3:
If the same error occurs, it's necessary to contact a service representative.
for other more help visit https://cbrtechsolutions.net
Jul 30, 2012 | Canon LBP6000 Laser Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Error code oxc18a0001 on an HP 3210 HELP
this is an ink error code:
try the following;
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again
Jul 31, 2009 | HP Photosmart 3210 All-In-One InkJet...
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
Error code C 6400
This code is a fuser problem code. Follow the procedure below. If the code does not reset or comes right back then: you will have to check the thermistor, thermo fuse and fuser lamp. If 1 or more are defective then replace. After you replaced the defective part you will have to clear the error code again.
Here's the way to reset that fuser code;
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Jan 27, 2009 | Office Equipment & Supplies
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
914 people viewed this question
k24674
