just want know how to peak the power back up on my 29 ltd classic. its only putting out 2 watts on ch. 20 I suspect someone had a linnear on it prior.
Comments:
Oct 09, 2009
- Im ok id say but i have some things off the web but just want be sure about what im doing. So do i adjust those with a power meter attached to see what it is doing. And will it effect the clearity of the radio? And what kind of power can i expect out of it
How electronically able are you? I can tell you how to do what most call the super modulation mod, it isn't too hard and isn't very expensive. (Unless you take it to a CB shop!)
Comments:
Nov 04, 2009
- It can be done with a good power meter, but to do it "properly' takes some expensive equipment and the technical service manual.
If you put a good power meter on it and adjust those components I indicated, you will see the results on the meter. When I used to do this I adjusted for maximum and then came down just a bit so as not to "stress" the components in the circuit and burn something out.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Please give more info on this. I would like to know all i can before i do anything to it and do i adjust these with a meter attached. Please advise
" - p_w_man81
