Question about Keurig B50 Coffee Maker
Coffee has been coming out diluted.
The coffee has been coming out very watery. The machine was working fine before this. I spoke to a Keurig rep on the phone and her only advice was to clean it with vinegar. We've only had this machine for 2 weeks. Is there any other reason why it would be more "watery?"
  • 79 Answers
SOURCE: Weak Coffee
I don't have any first-hand experience with this brand. However, it sounds like the coffee grounds are being partially bypassed by the hot water.
One clue that will help diagnose this is: does the carafe fill up to the amount of water that was in the reservoir? If not, that suggests not all the water is being cycled through.
See if the reservoir is completely empty at the end of the brew cycle. Look for any coffee-colored water in the reservoir at the end of the cycle. That would indicate, to me, a defective feed valve in the water path.
Posted on Apr 01, 2008
ginko
  • 19396 Answers
SOURCE: Coffee out of the machine seems too watery
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on May 22, 2009
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
cmccune04
  • 213 Answers
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 14, 2010
tgmusicgirl
  • 91 Answers
SOURCE: The water will not go through the pod to make the coffee
This sounds like the pin used to puncture the K-Cup is clogged with something...
since a K-Cup is not used when making conventional Tea, this sounds like you need to remove the k-cup holder, which, by the way is a 2 piece unit on the B70 models... and I believe is the same for yours...
the lower third of the k-cup holder snaps off... revealing a better look at the Piercing Pin.
Looking at the sharp pin inside the holder, you should notice that it IS hollow... and you need a metal... not plastic coated paper clip and get it through the piercing needle.
I think that will do it...
Posted on May 18, 2010
How do reattach the arms on the Keurig
The best advice is to clla the company and have a technical rep run you through the process to prevent permanent damage to the arms. Tel. 1-866-901 brew.
Feb 01, 2014 | Keurig Elite B40 Coffee Maker
Lights are flashing but nothing works
i had the exact same problem. when i spoke to a keurig rep, it was suggested that i open the kcup hopper and using a paperclip, clean the three holes in the upper needle. you have to straighten the paperclip so that it will reach about 1 1/2 inch into the hole.
there are three holes that need to clean and the back one, of course, is usually where the problem is. be aggressive! you need to twist/spin the paper clip as you push it in and out. after reaming all three, run a hopper of water through the system. i had to clean my pin three times before my brewer was working properly.
lots of luck.
Rob
Sep 21, 2012 | Keurig Elite B40 Coffee Maker
My coffee tastes watery. It seems as though the water flowing through the filter is going too fast. My other Keurig at work brews much slower, and the coffee is delicious.
Hi, Your coffee is ground too coarse. Make the grind finer as this will slow down the flow rate. If you go too fine it will just dribble and over extract the coffee."bitter". Dazza REPAIRER
Sep 23, 2011 | Keurig B60 Coffee Maker
Coffee seems very watery to me no matter what size I select or cup I chose. Is there a setting/step I'm missing that I should have it set on?
Hi, The bottom needle under the cup is plugged or missing...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 06, 2011 | Keurig Platinum B70 Coffee Maker
My coffee tastes very watery......same settings as usual. I am getting a full cup so it is not clogged.......
Hi, Bottom needle in K-cup holder is either plugged or missing...
heatman101
Jun 30, 2011 | Keurig B60 Coffee Maker
Weak Coffee
Dec 28, 2007 | Keurig B50 Coffee Maker
Keurig B50 Coffee Maker Logo
432 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
