Question about Philips 55PW9383 55" Rear Projection Television
Picture has a blurry bottom. The bottom 6 inches is blurry, if there are words its hard to read. There is also a red tint arc in the middle at the very bottom of the screen.
    Top Expert:
  • Philips Master
  • 14,553 Answers
If picture looks 3d and will not adjust (select convergence in the customer menu) one or both of the STK-392-120 CONVERGENCE CHIPS ARE BAD.
What needs to be done if this is case is to replace both chips and any of the 6.8 ohm protect resistors around them that are discolored or bad---I did one of these sets a few days ago--repair takes about a hour.
The parts for this repair cost less than 20 dollars if you buy them on EBAY. The real question is are you able to do the repair yourself?
If yes, I can give you instructions--it involves getting at the chips--unsoldering all 18 pins on both--checking the resistors around them etc.
If you cannot do this repair--shop around your area--most shops get 300-400 for this repair---the one I did the other day I charged 250 total---in home parts, labor, house call--everything.
MAKE SURE IF YOU GET SOMEONE TO DO THIS THEY REPLACE BOTH CHIPS! Some idiots will come out and just replace one chip---the set is going to have the same problem in a few months----
Once both are replaced and the set adjusted--it will not have this problem again for 5-8 years.
Clearly I do not know if you can do this repair---I am here to help people-IF YOU HAVE ANY QUESTIONS OR NEED HELP---do not hesitate to ask me here .....
Regards, SD TECH
Posted on Oct 07, 2009
Tv is alittle blurry, its hard to read words
when its hard to read words its usually the sharpness which make the t.v.'s look either blurry or sharp or right in between. you can fix this by adjusting it thru your tv's menu either on the tv or your remote, look under the picture tab in the menu and there should be a sharpness adjuster there. adjust as needed
Oct 13, 2009 | Televison & Video
Red lines, blurry picture
try this link. It fixed my sony.
www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Dark band 6 inches wide middle of the screen
YOU MAY HAVE A DEFECTIVE Y DRIVER BOARD OR A RIBBON CABLE THAT HAS COME DISCONNECTED. THIS NOT USUALLY THE PANEL SINCE THE PANEL DOES TURN ON. TAKE IT TO AN AUTHORIZED SERVICER.
Apr 10, 2009 | Televison & Video
Panasonic hdtv blurry
you had a failure on the video part of the main board or in the power supply . you are stuck calling for service there is nothing simple about these new tvs used to be we changed a part or two . today there is no parts changeing just board changeing and the cost is high . good luck you will need it
Mar 22, 2009 | Panasonic TH-50PX75U Plasma HDTV
Blurry picture with arcing
this is the the fly back transformer ,replace it or if you are not a repair man ,please contact the nearest repair shop.(risk of shock hazard -high voltage!!!).
Jul 31, 2008 | Toshiba 36A40 36" TV
D52W20 circuit board
The center circuit board is the green CRT drive circuit. that board could be bad or the green CRT could be faulty. I have access to both those parts for your model
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Help with settings - blurry SD picture
contrast full, brightness, tint, color, in the middle, then adjust sharpness for what suits your eyes, you may turn brightness and color below middle.
Mar 17, 2008 | Sony BRAVIA KDL-40V3000 Television
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Philips 55PW9383 55" Rear Projection Television Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
