Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Dear . experience
when i turn on computer my floppy drive doesn't have any reaction & in MY COMPUTER menu doesn't show floppy drive .
  • 70 Answers
When you start your computer, is the floppy drive detected in the BIOS? or is it Enabled in the BIOS? you have to enable the floppy drive in the BIOS for it to be working. Plus can you double check if you inserted the power cable and data cable properly? The cable might be loose. Double check.
Posted on Dec 24, 2007
How to Create a Startup Floppy Disk?
Insert a floppy disk into your computer's floppy drive. Open My
Computer, and then click the floppy disk drive to select it. On the
File menu, point to the name of the floppy drive, and then click
Format. Under Format options, click Create an MS-DOS startup
disk .
Oct 19, 2016 | Computers & Internet
Currently have a samsung floppy drive device manager shows its installed but not showing in computer bios changed to make as default boot device system doesn't recognize it have a PANASONIC product...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to either swap floppy drive or boot up floppy seek both could be disabled press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
May 07, 2011 | Panasonic (JU-256A216P) (JU256) External...
I have a gateway m285-e and can't get XXp Sp2 to recognize the Hard drive. How do i fix it??
hi guy
just follow this guide it'll help you
fisrst of all get the driver from here :
then follow this guide
Note: Installation of this driver requires the use of a floppy disk drive. If your computer does not have an internal floppy disk drive, an external USB drive can be used instead.
Download the driver file to the desktop, and then perform the following steps.
1. If you have not already done so, locate and double-click the D00455-001-001.exe file that you downloaded from the Internet and execute the file. Files extract to the C:\Cabs\D00455-001-001 folder on your hard drive.
2. Insert a blank floppy disk in the floppy disk drive.
3. In the C:\Cabs\D00455-001-001 folder, double-click F6flpy32.exe.
4. Click OK to start the disk creation.
5. The disk creation dialog box closes when the disk is complete.
6. During the installation of Windows you will need install this SATA controller driver. Press the F6 key on your keyboard to install a third party controller driver.
7. The Windows installation program requires the use of a USB floppy disk drive and the floppy disk that was created above.
8. The Windows installation procedure attempts to load the drivers twice; once directly after the F6 selection, and a second time after the installation files copy to the hard drive.
9. Select the "- Intel(R)82801GBM SATA AHCI Controller Mobile ICH7M" option as listed.
Note: To find the required selection it may be necessary to scroll down even though there is no indication to scroll down.
Note: If you experience any recognition errors during the installation, please reference this Microsoft Knowledge Base article KB916196. This article explains which USB floppy drives are supported by the Windows installation process.
Because the computer must have these SATA drivers when using a non-Gateway supplied operating system, these drivers are necessary and should not be removed.
just let me know
Oct 15, 2009 | Computers & Internet
Want to install xp without no cd drive or floppy drive help plz
Sure can.
Go to the BIOS menu, and select Boot from USB, or something close to it. (different companies use different terminology.)
Once that is done, use a USB CD/DVD rom and use the installation cd.
Please don't forget to rate is the answer helps
Oct 14, 2009 | Dell OptiPlex GX260 PC Desktop
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Asking to format
If this is a new floppy then its advisable to format it.
But if it has been formated before and the message still comes on then ignore it.
Also if you're denied access (Copy or Read) to the floppy then please reinstall the drivers and the floppy drive again using the installation manual
May 21, 2009 | Sony (MPF82E-U1) External Floppy Drive
Brand new Mitsumi internal floppy drive not recognized by Windows
Check the BOIS setup. Press on boot and see it the Floppy drive is turned on.
Mar 05, 2009 | Mitsumi (D359M3 SILVER) Internal Floppy...
Dell GX260
You need to change the boot order in the bios of the computer. It is also called the setup. When you turn the computer on, in the top right hand corner of your screen you will see F2-Setup F12-boot menu. Select F2 and when you get into the bios go through the options until you find "boot order" or just "boot". That will show what devices your computer will use, and in what order, to boot up. If the floppy is below the main hard drive then it won't work unless the hard drive is defective. Move the floppy to the top of the list, exit saving changes, and it will now check the floppy first.
Dec 11, 2008 | Dell OptiPlex GX260 PC Desktop
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
