Question about Dell Latitude C840 24X CD-R W/ DVD Combo (SIDE Unit) - D1361 CD-ROM Drive
Dvd does not show in BIOS
Same as the other guy. The issue is not the media in the drive but that the drive will not show in the bios. Have tried another drive known to be good in the same laptop and it does not show in the bios either.
    Scholar:
  • 150 Answers
Try this, it should work; Click Start>Run>Regedit>
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
Delete All Value Data from UpperFilters and LowerFilters
But before trying the above, kindly restore the registry entries as back up.
Warm regards,
Anirban Mazumdar
Posted on Oct 07, 2009
My startup Screen Says Media Failure Check Cables
Go into your BIOS when computer is first turning on press F2 or DEL to enter your computers BIOS look through the settings to find your HDD see it one shows up in your BIOS, then on the same page look to see if there is a cd/dvd drive listed as well, next if you have any flash drives or external HDD hooked to it remove them. After you have done these if your BIOS shows your hardware anyway. Power on you computer and see what happens. If you need more help, or come up with more information about your problem please reply. I will try to assist you further.
Jul 29, 2011 | Toshiba Satellite M35X-S111 Notebook
Screen displays low illumination.dvd drive not functioning.tv ok, av in ok.
Screen Display Issues:
Go to the BIOS. Once you power on the laptop immediately hold down the F2 key then BIOS will show up. Try to check in BIOS if the display has low illumination if yes then try connecting your laptop to an external monitor then toggle the display to the external monitor. If the display from the external monitor is fine then it means the LCD has issues and needs replacement. But before going into any LCD replacement try to update the BIOS version first.
DVD Issues:
Check first the DVD icon in My Computer window. If missing then kindly do this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318
Delete the upper and lower filters.
Uninstall the DVD device driver from device manager.
Restart the computer.
Check BIOS if ODD or DVD is present. If yes then F12 boot to DVD if failed replace DVD drive.
If the DVD not present in BIOS replace DVD.
May 28, 2011 | Computers & Internet
I have an HP pavilion slimline s3600f desktop pc and the optical disk drive doesn't seem to be reading cd's or DVD's.
Check the Device Manager to make sure that the OS does not have any issues with the device. If there is an exclamation point ( ! ), then Windows has issue with it. If there is an " ! " then right-click on the device and select update driver.
If the drive shows in My Computer, right-click on the drive and select "eject" from the list. This will verify that the OS is talking to the device.
Check your BIOS settings to make sure that it appears in the BIOS and is not disabled.
Also, Microsoft recently released an update to disable Auto-Play on CD/DVD drives. If Auto-Play isn't working (due to this update), then put a music/movie cd/dvd into the drive and open Windows Media player and try to play the disc through there.
The drive may not be "broken" it just may be that auto-play has been turned off by Microsoft.
May 24, 2011 | HP Pavilion Slimline s3600f Desktop PC
I have a DELL imension 3000 that is showing a blank screen when booted up. I have ran an express diagnostic check and it has given me the following error: Error Code:0f00:136C IDE Device Failed: Blank...
1.If there's a cd or dvd in the cd/dvd drive, remove it and try booting again.
2.press DEL at the start up screen to go into BIOS. go into BIOS and change the boot sequence options, set it to boot from the hard drive.
May 22, 2011 | Dell Dimension 3000 PC Desktop
My Lifebook C2340 won't recognize it's own DVD-ROM. When I set the CD in the BIOS, it goes back to "None". It doesn't show up in My Computer. I've cleaned the contacts and tried another DVD. Still won't...
Does it show the device in the BIOS? If not then there could be a problem with the motherboard hardware. If it is not showing up in the BIOS then I would first verify that the power connector for the drive has voltage. Also verify that the slave/master jumpers are correct if the drive has any. You could also try downloading the BIOS update from Fujitsu and see if after updating the BIOS it brings the cd-rom drive detection back. If the BIOS is seeing the drive but Windows is not then the problem could be with the Windows drivers or installation. You could try going into the control panel for windows and use the "detect new hardware function" and see if Windows detects the drive.
Dec 16, 2009 | Fujitsu LifeBook C2340 Notebook
Vt82c693a motherboard cant show ide hdd in award gui bios check
There may be a need to check the Jumper settings on the IDE drive, I would make sure the jumper is in the master setting and also to try to keep the cd rom connected also when you boot it up again.
Blessings,
A/V Media Guy
Nov 21, 2009 | Computers & Internet
Hi, my problem on dell inspiron 1526 is this: SYSTEM MODULAR BAY cannot be indentified.... problem is that CD/dvd drive show signs of work(when i turn my computer on Green led blinks,motor starts to rotate...
If the drive functions in another system the the issue is either the motherboard contacts or the controller. Flash the BIOS to the most current version and reset the BIOS defaults. If the drive still doesn't detect, then a motherboard replacement is likely in order.
Nov 15, 2009 | Dell Inspiron 1526 Laptop
K9MM-V mB with DVD and CD drives .running XP pro .
make DVD drive the master, and Cd drive the slave. by set pin then have bios re search for them and try xp new hardware search with the new configuration
Jul 08, 2009 | MSI K9MM-V Motherboard
How to install Redhat Linux 4.0 on Acer Power Series with SATA.
So did you try to install with and IDE dvd drive? Might be a BIOS issue, update bios or get a ide dvd drive somehow...
May 06, 2009 | Acer Computers & Internet
Easy Note W3332 BIOS shows NEC DVD + RW ND-6650A; does not play DVD's
You will have to go to the manufacturer of the dvd player itself. In your device manager, find the maker and model number of the dvd drive. Go to that company's site and look under support. There you can usually find the bios updates for every model. Flash the bios on the dvd drive. This is for the dvd drive, not the motherboard. This should fix any problem you have with the drive being recognized as what it actually is. Hopes this helps!
Nov 24, 2007 | Computers & Internet
Computers & Internet Logo
121 people viewed this question
Alun Cox
