Question about Garden
Wont start, new coil,batt, wont spin over - Garden
  • 437 Answers
Check the solenoid, Make sure the starter gear is not stuck in the flywheel, Pull the spark plug out to see if you have a cylinder lock problem(this is when fluid, oil or gas, get on top of the cylinder and cannot be compressed.) Check to see if you are getting power to the starter when you turn the key. Please be careful.
Good day
Posted on Oct 07, 2009
Starter fuse location
No gas, weak battery (battery may be new but is it charged?), crankshaft or camshaft sensor is bad, fuel pump bad, fuel pump relay or fuse is bad, haven't pushed clutch down far enough(rug caught underneath), fuel filter clogged, ignition coils bad. You need to give a hint as to what you have tried. Does it crank but not start/ Does it simply click(starter) and not crank/
Aug 09, 2014 | BMW X5 Series Cars & Trucks
It cranks but wont start. replaced starter, coil, spark wires and plugs. crankshaft position sensor, distributor and cap. still wont turn over. fuel pump turns on fine, and there is pressure at the...
the ignition module probly bad-replaces points and located in distributer area--batt must also read 12.6v and alternator must be healthy--fuses may not all be good--take a light tester to um--make sure inline safety fuse on the batt line is workn
Oct 10, 2013 | 1991 Jeep Wrangler
95 buick regal 3.8 car wont start no lights at all on dash unless u jump it then lights come on but still wont start
check all your fuses and your coil/coils, could be your alternator. check your distributor cap also, points, tightness, etc.
Jul 08, 2012 | 1995 Buick Regal
Wont start.
Crank sensor faulty.
Nov 26, 2011 | 2001 Pontiac Grand Am SE
My car cut off while i was driving....i have a new ignition coil, new battery, new rack and pinion and a new radiator
that is a simple fix to the problem you are having, even though you have a new batt. and ing. coil, the problem your having is your altenator, it is commen for them to go out over time, that is why your car died or cut off as you said while you were driving, if your ALT. goes out your car will start and act normal until your batt. is drained out then your car will die while driving, if theres no power to your computer on your car it wont run basicly like a hard shut down, but of your car....hope this helps
Mar 09, 2010 | 1995 Mitsubishi Diamante
88 mustang wont start, was running, replaced batt,starter,relay. relay clicks alot and batt is being drained.
did you try the ignition coil or try the fuel cut off switch in the trunk on the left side if the red button poped push it back in
Oct 11, 2009 | 1988 Ford Mustang
Truck wont start keeps blowing the ecm batt fuse
You have a short (bear wire) somewhere. Trace the wire and find it.
Have a great evening
May 01, 2009 | GMC Sonoma Cars & Trucks
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
