Question about Fuji Finepix J100 Digital Camera
Fuji J100 camera will not turn on.
I have a Fuji J100 camera. The camera will not turn on even though the battery is fully charged. Can anyone help me?
5 Suggested Answers
SOURCE: logitech pocket digital camera
Same happening to me. The solution is to try it in a different USB port, as it is a USB related issue.
Posted on Jul 21, 2008
SOURCE: my Cannon G9 digital
My g9 was working fine and then..... I went to take a picture, powered up and that was it. Can't take a picture, lens stays out, can't turn it off, it will do nothing at all. Battery is fully charged. HELP!
dw
Posted on Oct 06, 2008
  • 24 Answers
SOURCE: Digital camera not working
Battery must be ok. Check the switch contacts. Battery contacts.
Posted on Sep 11, 2009
Obertelli
  • 3006 Answers
SOURCE: camera lens is stuck out and wont retract. Camera
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 10, 2010
The camara fell into water for 1 sec can it be fixed. fuji Finepix J100 digital camera
Let it dry out near a heat source & tryagain in 24hours.If not it`s kaput and it might be cheaper to get a new camera Fuji have a repair or exchange service but it will cost you.
Aug 13, 2010 | Fuji Finepix J100 Digital Camera
Why is my fuji finepix j100 camera giving blurry photos , even looking through the lens the images are blurred and when the picture is taken its the same
SOUNDS LIKE A FOCUSING PROBLEM
HAVE YOU SET IT TO MACRO SETTING AND NOT SWITCHED BACK.
DISTANCE VIEWING ETC., WOULD BE THIS WAY
Feb 15, 2010 | Fuji Finepix J100 Digital Camera
I put fully charged batteries in and turn on the camera and try to take a pic it shuts off. Can anyone tell me what to do to fix it?
I would double check your batteries, even try some regular AA's just to make sure since it sounds like a power issue with your camera. I have seen this on my my S5000 before, a faulty rechargable causing it to shut off when a picture is taken.
Jan 28, 2010 | Fuji FinePix S5000 Digital Camera
My focus lens is stuck in the open/out position. i cannot take photos, the screen says unable to focus. help!
It sounds as though the battery is low and the camera is faulting and has become "stuck" because of it.
I would suggest you try this first to see if it is.
Turn the camera off, take out the batteries and then re-insert with new ones or charge the old ones before you re-insert them. Make sure the batteries are fully charged.
This "should" jumpstart the camera back to the original configuration.
If this doesn't work please post back.
Hope that helps!
Nov 09, 2009 | Fuji FinePix S3100 Digital Camera
Sep 11, 2009 | Fuji FinePix F401 Digital Camera
Computer cant see photos
Install the software that came with your Fuji J100.
Jun 17, 2009 | Fuji Finepix J100 Digital Camera
J100 Battery Does Not Work
your battery is a NP45 Li ion ... even if it seems to charge ok it still could be bad ... if you can substitute another battery to make sure ... borrow one from a friend or take it to the place you purchased it and see if they will just try one of their batteries .. or you can see if it will work while its plugged into the charger ... if it does then its likely the battery needs replacing ..
Jun 16, 2009 | Fuji Finepix J100 Digital Camera
Camera will not turn on and battery is fully charged
Hi I am Vortash I know this might sound silly but check the battery is in the correct way round .. if your like me and changed the batteries to my easy share I forgot a couple of times and put them in the wrong way round ..( even we make mistakes ) reversersal of the batteries cured my problem and added to my embaressment lol .. other than that check the batteries havent leaked and if they have look in the battery compartment for signs of damage rust etc .. and if you are still using the easy share battery that came with the camera .. it might say it is charged but may not be mine was dead and wouldnt charge afyer about 6 months use .. Regards Vortash
May 17, 2009 | Fuji FinePix F10 Digital Camera
L 100 digital camera is not switching on though the battery is fully charged.
Try removing the battery for a couple of seconds then insert it again. Click on the power button, it should turn on and turn it off again to close the lens.
Oct 17, 2008 | Samsung L200 Digital Camera
FUJI F20 Won't Power Up - Good and Charged Battery
Fuji FinePitteryx refuses to power up,even after new lith. batteries were installed
Mar 04, 2008 | Fuji FinePix F20 Digital Camera
Fuji Finepix J100 Digital Camera Logo
82 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
