Question about Dewalt 2 Dc925 18v ½ Hammer Drill / Driver 18 Volt
How do i get the brushes out once i have took back case off
  • 2,176 Answers
They come out as an assembly and it appears that you would have to gently pry up on the bottom to start them out. I suggest going to Dewaltservicenet.com and typing in your model number for a breakdown on this tool and for part numbers and pricing, I just looked at it a minute ago and it is there.
Posted on Oct 08, 2009
I bought the Bissell Heavy Duty in Jan 2009 and now the brush will not rotate. I have gone through all the trouble shooting procedures and it still does not work. Is my vacuum under a one year warranty? If...
if the brush does not rotate when it is in use, chances are the belt is broken. Belts are common to break and should be replaced once a year under normal use. (once a week) and heavier use, more times per year.
If the brush itself is not rotating, meaning you took it out of the machine and it physically does not spin, then you may need to replace the brush with a new one. You can possibly get one at your nearest vacuum repair center.
Good luck.
Nov 19, 2010 | Bissell Vacuums
How do I replace the brushes on a Kitchen Aid k5ss mixer. I took the black plastic buttons and the spring out but the brushes seem to be stuck. One of the had pieces of what I think is carbon off the...
I normally CAREFULLY drill a small hole thru the centre of the brush and get it out with a hooked probe. The brass square sleeve that the brush goes into can slide out with the brush. Make sure that doesn't happen because if it does you'll be splitting the cases to get the brush holder wire back where it belongs.
Feb 14, 2018 | KitchenAid K5SS Heavy Duty Commercial...
Took out/put back black brushs/motor wont turn on
Hi TUBEARS, from what you’re describing, I suspect that one or both of the brushes is (are) not seated properly when you reinstalled them. The brushes need to be installed so that they both seat correctly on the armature's commutator or you won’t get any ‘juice’ to the motor. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the first file K45SSWH0.pdf (341.41 KB) listed under Parts List (1) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #18, 21, 22, 23 & 31, and Illus. No. 19, Brush & Spring assembly respectively.
The Parts List illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Feb 20, 2010 | KitchenAid K45SS Classic Stand Mixer
I have a two wheel jugs machine used for junior little league. The wheels will not get up to speed...can you help me?
I just fixed one with the same problem.
10 to 1 odd the brushes are stuck from sitting.
unplug unit.
take off the cover of the motor. 2 -7/16 nuts
there are 4 post one with black wire , white wire , ground and no wire.
you need to take off the two nuts on the one with ground and the one with no wire.
you can then remove the cover which will have the brushes inside.
once removed push the brushes in and out of the sleeve to loosen. spray with some liquid wrench or wd-40 and work back and forth. I took some steel wool and cleaned the copper where the brushes contact.
when you put it back together don't forget the scussion ring. it looks like a couple of potato chips put together. line up the slot on the casing with the nub on the perimeter of the brush housing,
slide it in while lining up the long screws with the holes in the housing. you will need to depress the brushes with a screw driver through the front hole , then slide it in . it will not go in the last 1/8th because of the scussion washer. tighten the nuts on the long screws and the gap will close. if you have the wheel off you can use a phillips screwdriver to hold the oth side , if not just hold the screw on the shaft with channel locks in the middle so you will be able to get the second nut started.
repeat on the other motor and you should be good to go
Joe
Feb 17, 2010 | Jugs Small Ball Pitching Machine
Vacuumed water - won't work
it sounds like the motor overload is cutting out.
it should automatically reset in time.
  • try removing the motor from the vacuum.
  • jump the motor. (power directly to the motor leads) be careful doing this! because once you plug it the motor will jump...keep your fingers from moving parts.
  • With the motor running, you will want to inspect the commutator -(where the carbon brushes push against)
  • if a blue spark is large and wrapping around the commutator then you will need to replace the brushes to begin with...in worse cases the armatures commutator would have to be cleaned with emery paper.... or armature should be replace. i think vacuum motors sell as a assembly...depending on what type of vacuum you have it might be better just buying a new one.
Oct 07, 2009 | Vacuums
My roomba 560 has brushes that spin one rotation then stop then you hear a click and they rotate one rotation stop over and over. I took compleatly appart cleaned, lubed, and inspected all looked good?
I thought my brushes were clean, but here is what I discovered, and it fixed my Roomba.
The yellow bearing on the opposite end the brush rollers from the gearbox will pull off the shaft. These bearings spun freely and looked clean, but when I pulled them off there was hair and junk between the end of the brush and the back of the bearing. When installed in the Roomba this gook warms up and gets sticky causing friction and stopping the brush from spinning.
Use a toothpick to pull this stuff out and the brushes spin free again. I was very frustrated, and this fixed it, works like new again.
Mar 16, 2009 | iRobot Roomba 560 Robotic Vacuum
Brushes won't spin on hoover steam vac ls
I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( http://www.hoover.com/pdfs/manuals/F7222900.pdf ) this is shown on page 10 figure 3-2. Clean that screen.
If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
Jun 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Middle brush problem
If this is new, get it replaced under warranty. Take your model number, serial number, proof of purchase and the brush block with you, or you may be able to do it at hoover.com.
May 25, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Roomba turning off after 30 sec.
I was having the same problem. Roomba would run for 30 seconds and then stop. I tried everything -- then I took the small rubber brush out and removed the small nut at the end. It was packed with dust to the point that it could not turn easily. I cleaned it out and now it is working like a champ. I think the automatic shut down was just a sign that there was too much strain to turn the brushes.
Nov 27, 2007 | Roomba Robotic Floor Bagless Vacuum
Dewalt 2  Dc925 18v ½ Hammer Drill / Driver 18 Volt Logo
100 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
