Question about Mitsubishi WD-62525 62" Rear Projection HDTV
My 62 inch mitsubishi tv was hit by lighting
My tv was hit by lighting and now it dont do nothing do you think i should try to get it fixed or is it dead
  • 458 Answers
Try to find a local repair centre & ask if they can give you an estimate on the cost to repair. A lightning strike can cause either minor damage such as just an internal fuse blown or can cause severe damage which will wipe out entire circuit boards which can be a costly repair. In this case it's usually not worth repairing.
Posted on Oct 07, 2009
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
Jun 22, 2011 | Mitsubishi WD-62725 62" Rear Projection...
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62 in 1080p turns on ,has sound but no picture
Your going to need to measure the various power supply voltages to see if its a bad main or power supply board
Nov 08, 2017 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Only 1/2 of my mitsubishi 62 inch dlp tv screen illuminates.
Sounds like one of the light sources has failed or half of the projection source has failed(first is more likely)
If your TV is still on warranty you may want to call them to come pick it up. I doubt you'd want to move this yourself since it weighs over 100lbs
Aug 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Lamp light flashing green continually after power outage. have hit reset button, unplugged tv, nothing works
the timer light will continually flash green.on the dm pcb and fmt pcb you have 4 capacitors
that pooch out.replace the 4 capacitors on both boards.will require a tv professional to do
this.
Jul 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking green light, no picture, no sound
This is typically the capacitor problem. Bad components on all of the electronics boards. There are many web sites with instructions on how to repair, but be advised that this is not always successful. Hope for the best!
Jun 14, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Device Menu not working
Could have a stuck button or a corrupt e-prom, but lets try kicking this set in the head, Now these reset codes are model dependent so this code will not work for every set out there but this reset is for the WD-62525. with the set on and with the original TV remote hit the keys in this sequence, MENU-2-4-7-0 this will bring up a service menu, the cruiser should already be on "Initialize" so simply hit enter. this will reset the TV to factory defaults and may fix your problem
Sep 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
200 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
