Question about GE Monogram ZDI15C Automatic Icemaker
Ge monogram model # zfsb26dnass serial # ld408815 the refrigerator display led lights will not display temp & the ice & water dispenser will not dispense but the led lights work on it. the refrigerator & freezer are keeping proper temp. this problem occured all at once. i have changed out the main control board, part # wr55x0942, this did not correct my problem.
  • jmikebaker Oct 07, 2009
    GE MONOGRAM MODEL # ZFSB26DNASS SERIAL #LD408815, THE REFRIGERATOR DISPLAY LIGHTS WILL NOT DISPLAY THE TEMP, THE ICE & WATER DISPENSER WILL NOT DISPENSE BUT THE LIGHTS ARE WORKING ON THIS. THE REFRIGERATOR & FREEZER ARE KEEPING PROPER TEMP. I CHANGED OUT THE MAIN CONTROL BOARD BUT THIS DID NOT SOLVE MY PROBLEM.
  • 10,515 Answers
The next 2 things that i can assume would be Dispenser Board and Solenoid.
Does the dispenser panel have a lock icon on it ?
If yes, then go ahead and hold in on the lock unit it locks and count to 20 and push in again and unlock it and try it. Then unplug and again plug in after 20 minutes.
If problem still persists, as i said, more likely it's dispenser board.
Let me know, if need further information.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
If that does not work, check if the fans are working.
Posted on Oct 07, 2009
  • GE Master
  • 19,396 Answers
I think that there may be more than one problem. Start testing the icemaker. If the icemaker is getting power, then the icemaker not dispensing is a separate problem. Test water valves, icemaker solenoid and motor.
Regarding the control problem, test wiring harness, and ensure that the replacement control assembly had been installed properly. Test all the temperature sensors, if one of them is shorted it can jam the control board. Fridge sensors must return an impedance comprised between few Ohms (about 40) and about 600K Ohms max. To find out values on your fridge, compare one sensor with the other ones. If temperature sensors are OK, check the humidity control board and double check all wiring.
Here all sensors present in your fridge.
Here all parts and diagrams for your appliance.
Please do not forget to leave feedback afterward.
Many thanks.
G.
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
Need to replace my ZISB42DCA should I go with latest Monogram or a comparable Profile or switch to Kitchenaide. We have had a lot of problems with this one but it came with the house.
I have a 42" GE monogram refrig: ZISB420DMC. Water dispenser has had all kinds of problems and I've already had it fixed once. Same for ice dispenser. I just get ice directly out of the bin rather than have it dispense ice. This refrig also doesn't seem to have very much storage space. I can't even put a large pot in the refrig because of that silly light in the back of the refrigerator. I don't like GE refrigerators anymore. I've seen friends and family buy the Samsung refrigerators. They are really nice and I would get a Samsung. Here in Hawaii, Lowes seemed to have the best prices on the Samsung refrigerators.
Aug 17, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
Its not working!
You are going to need to change the main computer.
Jan 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge monogram sidebyside refrigerator
check the flap thats lets the ice come out,i don't think its closing all the way,thats why your getting frost,the water dispenser problem is the water inlet valve on the lower back of frig. and should be replaced,let me know more-mike
Oct 21, 2008 | GE Monogram ZIR36NMRH Refrigerator
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
GE Monogram ZDI15C Automatic Icemaker Logo
311 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Sal DeAngelo
christian nielsen
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
