Question about Panasonic DVD-RV32 DVD Player
Does not play DVD and displays HO7. We have tried
Does not play DVD and displays HO7. We have tried cleaning and reseting the unit.
  • Panasonic Expert
  • 244 Answers
This normally means the spindle motor is faulty,there is a little coupler and this splits,this will cause the machine not to load.
Posted on Oct 08, 2009
Testimonial: "Thank you for your help. Does that meen that the DVD player can not be repaired by me?"
  • Jamie Andrew Knights Oct 10, 2009
    Find the spindle where it goes into the motor and spray some wd40 and leave for a while to soak in,you may have to do this a couple of times
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic DVD Player. Reads DVD then says HO7 and then STOP. PLAY DOES NOT PLAY
Common failure of the spindle motor/laser assembly. Also known as the traverse unit, which can cost more than a new player to replace. Not a consumer-repairable part.
Feb 26, 2011 | Panasonic Televison & Video
@Hello - whenever I try to insert a disk to play it starts reading it (display reads READ...READ and then it stops and displays HO7 and won't play the disk at all. I've had the unit a few years but have...
H07 is a common error code for Panasonic DVD players. It means the traverse unit (spindle motor/laser assembly contained in one block) has failed. Usually it is the spindle motor part of this unit which fails first, (i.e. it doesn't spin the disc at all) causing the problem, but sometimes the laser can also fail as well. Because the motor and laser are contained in one device block, the whole part has to be changed, and this can only be done by an authorised service centre. The only trouble with that is the cost. Many DVD drives experience this (different brands giving different error codes) so it's not just confined to Panasonic.
There are only 2 ways to go here; either be prepared to spend a fortune in a workshop service to have the traverse block replaced/aligned (which would include a brand new laser), or simply buy a new player - which would give you a new remote AND an optional extended warranty if available; this would be considerably cheaper than repairing the old one.
Don't be put off from owning Panasonic - they are generally good products.
Feb 24, 2011 | Panasonic DVD-RV32 DVD Player
HO7 displayed on machine and won't play dvd
email me your email address and i will show pic's how to my email address is markusmaritz@yahoo.com plzzz email me i will help but for now i will help step for step.
1)open your driver and pull out the plug.
2)nou the driver is open pull of the cover infront of the dvd player.
3)nou screw open your dvd player and take of the cover.
4)screw of the driver take it out.
5)nou clip of the lazzer and take it out gently.
The top resen of the HO7 is problem is it movement is dry use selicone spray to spray it there will be a thing that makes it spin but for screen shots plzzzz email me.PLZZZ RATE ME FOR NOU BECOUSE THIS PROBLEM IS NO MORE IT IS SOLVE FOR SHORE..
May 05, 2009 | Panasonic DVD-S35 DVD Player
Panasonic dd-s25 won't play dvd.
HI...
Have you tried reg.CDs to see if those have trouble too?
I would say that the lens assembly has got debris or a filmy substance over the lens.
If you're not the least bit technical , dont open the unit.
It will require that the cover gets removed and the top DVD spinner plate gets removed so that the Lens can be cleaned.
The chrome rails that the DVD reader runs on would need cleaing too.
Mar 04, 2009 | Panasonic DVD-S25
DVD error HO7?
Will read dic and play movie for about 10 mins and then stop and give me the error code H07. What is this and how do I get rid of it?
Feb 01, 2009 | Panasonic sa-ht800V Home Theater Audio...
Panasonic dvd RP82
well I have one of this items, and I could find an exelent tutorial, that show a graphic way to fix it.
http://www.elektr0n.com/dwm/doku.php?id=how_to_fix_the_h07_ho7_error_on_your_panasonic_dvd_player , this is so helpful.
Mar 07, 2008 | Panasonic Televison & Video
Not reading dvds or cds
press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE until innitiliazing appears try several times
Dec 25, 2007 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-LX9 "disc may not be played in your region" error
Try cleaning the lens with a cleaner?
So it only reads music/Audio CDs and won't play DVDs?
Do you get an HO2 or HO7 error? If it is that it might be
the spindle motor.
You might try this website also to reflash the firmware:
http://www.firmwareupdate.us/
Mike
Nov 09, 2007 | Panasonic DVD-LX9 Portable DVD Player
Panasonic DVD-RV32 DVD Player Logo
460 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
