Question about Delta Machinery Masonry Tools
I am looking for a shop manual for a rockwell ****** 37-260 jointer. The knives and and brackets need replacing
4 Suggested Answers
johncaman
  • 201 Answers
SOURCE: need info about circa1950's Rockwell/Delta 8" jointer
I can't help you with the knives, but I can help you with the motor - you need to find the plate on the motor with its specs. If it has a horsepower rating, just replace with the same horsepower. If it doesn't show a horsepower rating, I need the amperage (FLA), and the voltage, I can determine it from that. Please get back to me with both the horsepower rating and the voltage and FLA if you can, and tell me what voltage you are going to hook up to.
Posted on Mar 16, 2009
  • 10865 Answers
SOURCE: I AM LOOKING FOR A MANUAL FOR A ROCKWELL JOINTER 37-600
go to this site and call rockwell on the number provided.
http://rockwelltools.com/service_parts.htm
Posted on May 19, 2009
efs_perpends
  • 1996 Answers
SOURCE: I am looking for an owners manual for a Rockwell
I've had good luck finding them at this website, though you'll have to check both the rockwell and delta pages. Look for publication reprints, and when you get to the manufacturer's page, click on the Pub. type heading to sort the column into jointers, table saws, etc. You may be able to find something of comparable age that will have descriptions to help you, as many models had relatively slight variations from one another. I'm not sure what vintage that is, but there are general line catalogs and instruction manuals listed in the Delta pages that go back many years. Some of them will have basic jointer instructions that may directly pertain to your model. Also check that model number carefully. I've not seen letters in their model numbers before. Usually it is two, followed by three digits. Compare this link for an indication of what you could be missing.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 02, 2011
Does any know much about a Rockwell delta drill press model o-2140-a?
Rockwell Manufacturing Co. - Photo Index ...
vintagemachinery.org/mfgindex/detail.aspx?id=698&tab=4
02/24/2015, Jointer, 6" Short Bed Jointer, Model No. on Motor: JB82B710CW · 6" ...12/30/2014, Drill Press, Delta Rockwell Homecraft Drill Press 11-120 · 11" ...
Aug 27, 2015 | Delta Drills
I am looking for an owners manual for a Rockwell 6" Jointer Model #37-6CO serial # HW7441
Jun 01, 2011 | Delta Machinery Masonry Tools
HOw do I adjust the tables so I do not get a snipe?
Adjusting a jointer to relieve snipe can be trickey but here are a few procedures that will help.
-The two tables on the jointer are adjustable, the front (infeed) is what you adjust for cut depth.
- The back (outfeed) needs to be the exact hieght as your knives
The outfeed needs to be adjusted first
-unplug jointer
-using a straight edge on the outfeed table adjust it so that when you turn the head (counter clockwise) the knives just touch the staight edge (NOTE** all the knives should touch the straight edge the same, if not your knives are not set correctly) This is your most important adjustment, if the outfeed is to high or to low it will cause inconsistant jointing.
-Now that the outfeed is trued up to the head you can adjust the infeed table, using the straight edge align it so that it is perfectly lined up with the outfeed table (not touching the kinives) Your jointer is now at ZERO
You can now adjust the infeed for depth of cut, Start by lowering the infeed a very small amount (1/16 of a inch to start)
The biggest problem I have seen is that people try to cut to much at one time, it will work alot better if you take several small cuts instead of one deep cut.
Also- getting the knives set perfectly in the head is a key to success, if this is not happening you WILL have jointing problems. ALSO if the knives are not sharp they will pull the material down causing snipe.
I really hope this helps and if you need a visual aid try looking it up on you tube.
I have used my jointer for numerous different projects, Here is a cool one for tapered table legs.
Take a piece of square stock (like 2x2 ) about 3 feet long, make a mark about 2 foot up and wrap a piece of tape around it at the mark.
now make a mark (we will call it a stop mark) on the fence of the jointer by the head.
with a pencil and number the edges on the 2x2 (above the tape so you dont joint them off)
turn on jointer and run side 1 until your tape is at the fence mark, carefully lift 2x2 and do the same to the 2 side.
only joint the #1 & #2 sides, run several more times and you will have a perfect tapered leg.
SHOP DOG
May 02, 2011 | Masonry Tools
How do I change jointer knives
There are quite a few things involved in changing jointer knives (to do it right that is)and without knowing the details of your machine I can't give you a exact answer. BUT there is help.
Go to you tube and you will find several videos on the subject.
Also you will need a set up tool ( its a magnetic device that holds the knives to the same height).
The most important thing is to have all the knives set the same in the head (i.e. set up tool ) and if you can afford it purchase the dial indicator for jointer set up this will make them perfect. you will see them using it in the videos along with the magnetic type.
I have been using jointers for years and am still learning new things that I can do with it, but set up is the key to a good end product.
Hope this helps.
Shop Dog
Nov 23, 2010 | Garden
I'm seeking an owners manual for a Rockwell Jointer model 6
http://www.ozarkwoodworker.com/item/rockwell-6-jointer-instruction-and-parts-manual/
Sep 04, 2010 | Garden
The knives on my Delta jointer don't contact the trailing edge of the board. As a result the board has a convex edge (high in the middle) The tables are parallel and the outfeed table is flush with the...
The knives could be dull, you would have to be the judge of that. If the bevel & face are rusty they are probably dull. They can be honed or taken to a sharpening shop.
The outfeed table could also be too high. I usually adjust the knives above the outfeed table. I use an aluminum straight edge & adjust them using a sheet of printer paper on the outfeed table so that they are about the thickness of the paper above the table. I place the paper on the outfeed table put the straightedge on the paper & rotate & adjust each knife so they just slightly hit the straightedge when I rotate the cutterhead by hand. Needless to say the jointer needs to be unplugged while doing this.
The board could also be convex to start with. To fix that problerm start jointing at the start of the convex part and not at the end of the board.
Good luck,
Frank
Jun 17, 2010 | Delta Machinery Delta 37-658 Jointer...
Need info about circa1950's Rockwell/Delta 8" jointer
Mar 16, 2009 | Masonry Tools
Can not find replacement blades for delta jointer
I can't get a hit on that number, the model must be other. But it shouldn't be too hard.
Try to find a reliable sharpening service in your area; someone who does saw blades and knives for the cabinet shops will have a source for tool steel and carbide and can make you a set of knives for your jointer. Just get tool steel. While it won't hold it's edge quite as long as carbide knives, it will take a sharper edge to begin with, and should last just fine if you don't run sand through it.
If you have the original knives, hang onto them as they most likely can be resharpened to like new condition, and steel today ain't necessarily what it used to be.
The critical factor is the height. It's usually between 5/8" and 3/4" tall. You want them to be able to rest all the way down on the adjustable pistons without sticking up more than 10-15 thousands above the cutterhead. That will give you the most resharpenings from a set. You might want to invest in a magnaset to help with setting the knives in place.
Here's a link to the sharpening service I use: http://maps.google.com/maps?rls=com.microsoft:en-us&oe=UTF-8&um=1&ie=UTF-8&q=Precision+sharpening+%2B+Albuquerque,+NM&fb=1&split=1&gl=us&view=text&latlng=15322695688682105671
Finally, I would almost bet some contemporary delta replacement knives would work. If you find a place that will return your funds if they don't, you might be able to order them online. These guys will carry them if you can't find someone nearer you: http://woodworker.com
If I've answered your question or solved a problem, please take a moment to rate this posting...thanks!
Mar 04, 2009 | Delta Jointer Blades 6 Inch Fits , Jet...
Masonry Tools Logo
100 people viewed this question
Top Delta Machinery Masonry Tools Experts
Tom Chichester
Are you a Delta Machinery Masonry Tool Expert? Answer questions, earn points and help others
