Question about Sharp AL-1655CS Copier
Cannot scan using Sharp AL-1655CS
I can print to the Sharp AL-1655 CS but I cannot scanner - states that scanner driver is not installed.
    Guru:
  • 389 Answers
Make sure that you install the driver for your operating system. Check the stop of the scanner under copying table to the left.Do installing the equipment from panel of management. Check in "system" of the "panels of management" consumption resource of your printer and scanner. The Driver of the scanner is fixed from printer apart. Arouse update the drivers in accordance with your operating system.Windows or Vista or Linuks on put www.sharp.com
Posted on Oct 08, 2009
Need driver for Sharp al 1642 cs with windows 64-bit
Please communicate with me through my email then i will send driver to you. thanks
Nov 05, 2012 | Sharp Al-1642cs Print/scan/copy
I have a AL 1655 CS and it stopped working! I've stopped it and started it, changed the cartrige and open and closed dorrs!! It says System Error [L1-00] what next?
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Aug 16, 2010 | Sharp AL-1655CS Laser Printer
The lamp scanner bulb broke. I have a Sharp AL 1655 CS
look for the sharp dealer in your area, we have one here in the Philippines.
Mar 17, 2010 | Sharp AL-1655CS Copier
Err0r l1 00
If you hear any cracking sound if you are not please clean all surface scanner area.Clean scanner sensor
unlock position .
Oct 07, 2009 | Sharp AL-1655CS Laser Printer
I need the scanner/copier part of the driver CD - Sharp AL-1655cs
I'm not sure where you downloaded the printer driver but the Sharp website has a download link to the printer and scanner driver according to their website.
http://www.sharpusa.com/products/TypeSoftware/0,1086,20,00.html
Aug 20, 2009 | Sharp AL-1655CS Laser Printer
My sharp al 1655 says replace td cartridge. what is this?
It means that you should replace the toner and developer cartridge.
Jun 03, 2009 | Sharp AL-1655CS Laser Printer
The scanner copies everything with a dark shade. This happens when making copies and when using it as a computer scanner. It does print fine however. Everything was working fine until I took the toner out...
check the image density setting on the screen, put it at auto or mid way, if it is move it to the lighter side, Printing does not use the density setting. scanning and print do. let me know if this works
Apr 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Al1655
i need the driver of my 1655 cs for xp , where i found, www.sharpusa.com no,
Feb 12, 2008 | Sharp AL-1655CS Laser Printer
Sharp al 1655 false paper jam message,
Check that the paper feed roller is clean as if the roller slips it causes a late paper pickup jam but nothing will be in there also maybe a small torn piece in the machine some where. and check the fuser make sure that is it not stuck in there if no to all these then is will need a control board.
Thanks J
Nov 17, 2007 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Copier Logo
300 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
