Question about Nikon Coolpix S1 Digital Camera
I cannot turn my camera on. I've recharged the batteries and tried different batteries and still cannot turn the camera on.
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
My finepix s3400 will not turn on. I've tried almost everything and I'm really annoyed. Is there something i can do to fix it?
Mine wont turn on either, the battery is fully charged and inserted properly. I can tell this as the pre-flash light comes on but nothing else, the only way to get the pre-flash light off again is to remove the battery.
Mar 08, 2012 | Fuji FinePix 3800 Digital Camera
I keep getting the message "battery exhausted" on my Nikon Coolpix L22 camera even when I've replaced with new alkaline batteries. They are not rechargeable batteries though. I've tried...
Try rechargeables anyway just in case.Sometimes with age these cameras don't work well with alkalines. If that still doesn't work then I would suggest contacting your local Nikon authorized service center.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon COOLPIX L20 Digital Camera
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
The light on the end of the dock stays red. Battery when recharged turns green. When placed back on the dock, then the light goes back to red.
Turn your camera on and look at the battery life after you had it charging for a while. your rechargable batteries may be bad or getting bad. Try trading out the rechargeable batteries or try plugging in your charger on a different outlet at home
Mar 04, 2011 | Cameras
My camera won't turn on, even though the batteries are fully charged. HELP!!!
the batteries might be to old. rechargable batteries go bad after a lot of recharges. you can get new batteries at wallmart and other stores!! Good Luck!! :)
Apr 03, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Battery won,t charge
the price of KLIC7001 $29.00 try to purchase the battery at wallmart target or at kodak.com/go/shop.,
how do you charged your camera USB cable or AC adaptor? if USB cable make sure that the Cable is working fined and the USB port of a computer is not defective., If the AC adaptor., try to clean the 3 metal contacts of your KLIC7001 using clean dry cloth, then charge it again. if its failed., try to test first the camera itself using different KLIC7001 if its not charging it means the problem is on the camera not the battery
Nov 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Batteries
You can try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries and you will see a difference.
Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
May 24, 2008 | HP Photosmart M22 Digital Camera
Same problem
your batteries are dead.
Oct 27, 2007 | Samsung Digimax S500 Digital Camera
Nikon Coolpix S1 Digital Camera Logo
27 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
