Question about Slendertone Fortex
The middle pad does not contract buty the little ones do and I do not have an instruction manual
On a call when I try to use dial pad to enter numbers the dial pad won't stay on. Is this fixable?
YES IT IS FLEXABLE. GOTO SETTING AND UNDER DISPLAY YOU MIGHT FIND THE ADJUSTMENT. YOU CAN ALSO GOOGLE THIS QUESTION TO FIND VIDEOS ON YOUR PHONE AND HOW TO VIDEOS. ALSO YOU CAN REFER TO THE MANUAL IF YOU HAVE ONE.
Feb 16, 2015 | Tracfone Wireless Samsung Galaxy Centura...
The date end of my contract for magicjack Plus
You should be able to get that information when your Dial Pad comes up on the computer screen. There are options listed on the Dial Up Pad and your information is provided from there. Other than that, go directly to MJ on line and seek their customer support.
Jan 06, 2014 | Computers & Internet
Black vertical line down the middle of my copies? This only happens when using the feeder.
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,
The Manual feed tray Uses A feed roller and a Seperation Pad
If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller
Instructions:-
open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .
close down the Service Hatch and return to machine -
You may need to run several pages through tray one before all tread marks Dissapear
Sep 13, 2013 | HP Color LaserJet 5500 Printer
Hi, Screen says (cable stretched). No picture. Lines start from both upper corners and then sag in the middle? All three bulbs are on. Sound works butis all ststic. Thanks Steve
If it looks 3D or warped it sounds like your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 26, 2011 | Mitsubishi WS-65909 65" Rear Projection...
How to update browser setting in forme q9000
hai can any one tell me how to go to main menu of forme mobile accually i oped shortcuts and i have done left as writing pad right as contract menu center botton as writing pad up camera,down contract number in keypad and i old ok now if i press any bottns i can open only hese things i cant open main menu can anyone tell what i am suppost to do
Aug 20, 2011 | Cell Phones
I have a Clarke MIG 130 EN welder, butI lost lthe Instruction manual& need a new one.
Hi and welcome to FixYa, I am Kelly
You can get your manual here: Manual PN 6014530
http://www.clarkeservice.co.uk/manuals/mig_welders/mig110e-160en.pdf
Manual is 290 kb Manual says it is 230VAC?
You may have to call them via this contact data to get a 110V manual:
Clark Power Products, Inc. 10752 N. 89th Place, Suite 104. Scottsdale, AZ 85260.
Phone: (480) 661-8599. Fax: (480) 614-0125
email: sales@clarkpowerproducts.com
Their 1-800 number stopped working in 2009 due to financial reasons.
Hopefully this will help you.
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | Clarke Power Products Clarke 130EN Mig 110...
Just replaced rear pads now it feels like i have air in the line, the pedal goes about 3/4 of the way down. i used a tool to turn the caliper piston in until it seated then put the pads on. now the abs...
that is how you contract the caliper on the Audi/VW rear brakes. I would check the brake fluid, I would also recheck the back brake lines as it is/was a bear to replace the rear brake pads. Hope this helped Tim
Apr 17, 2011 | 2000 Volkswagen Beetle
353C image transfer belt needs replacing. We are not allowed to spend on supplies and there is no maintenance contract to violate. Can I clean out the waste toner or reset something like I used to with...
Theoretically, yes, but Konicas might work a little differently than xeroxes. If you need a manual, either contact the manufacturer, or google Konica Minolta bizhub 350 manual. If worst comes to worst, you might be able to salvage a belt from somewhere. But whoever said you are not allowed to spend on supplies is an idiot(no offense if you were the one who said it). Using used parts instead of doing what the manufacturer reccomends is just asking for premature failure.
Feb 10, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Slendertone Fortex Logo
302 people viewed this question
Top Slendertone Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
