Question about Microsoft Xbox Console
Xbox 360 error 1022
Xbox 360 has secondary code 1022. need help. i fix my xbox 360 with 3 screws on GPU and CPU so i then unscrew it and put 4 screws on it and now it Gets the red ring of death. av cable have switch to another one that works.
problem is the heat sink on both don't heat up now. the fan turn on for 3 seconds then shuts off. leave on for 10 min the heat sink don't heat up at all. youtube channel is http://www.youtube.com/fenix0green i have one vid of it working then next day when i change to 4 screws it does not. and picture of the motherboard.
  • 1,234 Answers
Hi sir
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
Posted on Aug 26, 2010
SOURCE:
What does the code 01-80-00 mean on my xbox 360
3 red lights is one of the most common errors - to fix this you need to stop the heat build up getting to the GPU and the CPU. Use a good Xbox 360 Repair guide to fix this.
Mar 04, 2012 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
How to fix xbox 360 "red rings of death"??
How to Fix Red Ring of Death - A Step by Step Action Plan
Remember to rate me a 4 out of 4 thumbs up thanks
1) Disassemble Xbox 360 Case
Obtain your case separately. By a fine tip screwdriver, poke the grayed out holes and back of poke the small rectangle holes. Get the Faceplate Off and move the latch up on the DVD drive up as you remove it. Unscrew metal case which is under the plastic case.
Following is the image of video (How to disassemble xbox 360 case) which comes with James Dean's Professional Xbox 360 repair guide. If you are not comfortable with instruction you can use this video to disassemble your Xbox 360 case.
Click On Above Video Image To Watch Video On How To Your Repair Xbox 360
2) How To Remove Motherboard Safely
Unplug all cables connected to motherboard and associated small devices and take DVD drive out. After DVD, get the fan and motherboard out of the xbox 360 case. Make sure you do this gently.
Following is a quality video which can show how you can remove motherboard safely.
3) Crucial Motherboard Disassembles.
Turn the mother another side, using the screwdriver snoop off the X-clamp which you can find under heat sink. Check out following an image of a video which came with Xbox 360 repair guide which will make your process easy of "snoop off the X-clamp".
I will suggest you to do this step very gently if you are not comfortable doing this refer following video which comes with James Dean's 360 repair guide.
4) Heat Sink Unscrewing.
After snoop of X-clamp you have to unscrew heat sink to obtain CPU and GPU.I will advice you don't hurry to finish this work, please follow all steps else it will damage your xbox 360. If you are not confident do use Professional Xbox 360 repair guide.
5) GPU And CPU Cleaning.
Next step is to clean GPU (graphic processing unit) and CPU (central processing unit) If you do this step right it will help to stop xbox 360 freezing. This is very important and critical step so just make sure you do it right.
6) Appling Arctic Silver
Now you have to apply arctic silver thermal compound gently over GPU.
You will get this arctic silver thermal compound in any computer hardware shop for $1-$2.
Set it for 15 to 20 minutes then place 2 nylon washers on each screw on the heat sink then place the screws back in motherboard then add two more nylon washers to screws.
Then,
Place the heat sink on the peak of screws then push them down slight, finally screw them up. Try to make it reasonably tight.
Get everything back together and see everything is fitted properly. Now, Turn your Xbox 360 on.
I always like to educate people so I tried to describe a whole process in my words, Videos can make this whole process lot easier. I will suggest you to check out James Dean's Xbox 360 repair guide(Click Here To Visit) which will surely help you out to fix your XBOX 360. Also I have done a detail review of James Dean guide below, so don't forget to check it out if you need a pro help. please rate me high thanks
Jan 04, 2011 | Microsoft Xbox 360 Console
Secondary error code 0020 fix
Some consoles just aren't fixable. It's not common, but does happen. This is why I recommend only having a repair done by an experienced professional.
Dec 30, 2009 | Microsoft Xbox 360 Console
I have the 0102 code on my Xbox 360 can this be fixed and how?
The XBox error code 0102, is an error in the digital backbone or the CPU or GPU or RAM. This error is generally caused by a cold solder connection between the main board and the GPU. I would recommend calling microsoft about fixing it.
Dec 22, 2009 | Microsoft Xbox 360 Console
My xbox 360 has 0110 secondary error, pls help me to repair it. ty
0110 error is related to the rrod error here is how you could solve this problem:
e74 or rrod error means that there is an hardware issue.
What you need to do is a very simple and cheap repair.
look on ebay for x clamp repair kits, these are just a few bucks and most sellers include a good guide in how to do the mod/fix.
what causes the rrod or e74 error is the X shape clamp on the underside or the mother board bending and mis-shaping causing the ball soldering on the gpu/cpu slightly melting and forming hairline cracks in the solder.
The x-clamp kit will apply more pressure to the gpu/cpu and a little trick of disconnecting the fans and turning on the xbox and allowing it to overheat will re melt the solder ball joints to fill the hairline cracks.
Depending on which chip is the issue you may also need a 2000 watt heat gun instead of using the over heating method (the gpu chip).
Replacing the heat pads on the heat sink with thermal paste which comes with the kit will keep the gpu/cpu cooler and you wont have this issue again.
Please make sure you buy the kit which comes with heat treated nylon washers as the steel spring washes fail!.
The repair takes around 1-2 hours
I hope this helps in fixing you xbox.
Nov 01, 2009 | Microsoft Xbox 360 Console
My 360 has e74 error and the 2ed code is 1022 and sometimes 1021 but i already did the x clamp mod and i modded and put a fan over the cpu
The cause of the E74 Error might be overheating of your console and for avoiding such error messages in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling the console such as cooling the machine through a pedestal fan etc. But as your Xbox already have E74 Problem, You can either send your Xbox to Microsoft for repair ( just for your information Microsoft is no longer providing Extended warranty for E74 Problem), Microsoft generally takes 3-4 weeks to fix the problem. If you can't wait for a month (I know most XBox gamers can not wait without their favourite Gaming device), You can also fix E74 Problem yourself and that too within an hour without any technical knowledge. I would suggest you to check out the DIY Xbox Fix Guide for more information......
Apr 09, 2009 | Microsoft Xbox 360 Console
X box 360 error????
I cant get into xbox live my ip address works but xbox live doesnt
Sep 29, 2008 | Microsoft Xbox 360 Console
GPU Error. Code 0022 on my xbox 360
There is a very simple fix to this issue and I am not sure why it is not being talked about. I will have to make a video and post it for everyone to see, but in short, you need to overheat the GPU while keeping the CPU cool.
Now, if you do not know what you are doing, I would wait until I make a video about it. However, if you are comfortable taking your Xbox apart then it is simple.
You will need to disaseble the box all of the way down to removing the top cover and exposing the board. You do not need to remove the DVD or the fan, however you will need to take off the plastic piece that vents the fan air into the heat sinks. After you get that far, take the fan out of the case. DO NOT UNPLUG IT, as you will need it. Just pull it out of its holding spot. Next, you will want to move the DVD drive off to the side, away from the GPU heat sink, but leave it plugged in. Then set the fan on top of the CPU heat sink, the taller one, so that it does not overheat. Then turn your system on and let it RROD, then leave it on for about 10-15 min. What this will do is overheat the GPU and reflow the solder underneath it. After 10-15 min, turn your system off, let it cool, put it back together, and you should be good to go! I have done this on 3 systems that came up with error codes related to the CPU or GPU, and all 3 are now working again. Good luck!
Mar 22, 2008 | Microsoft Xbox 360 Console
Xbox360 error code
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
0023 (not yet known)
0101 (not yet known)
0102 unknown error
Oct 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
816 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
