Question about Philips FR975 Receiver
When I turn the vol. up past twelve the unit shuts itself off. I recently moved it and now this.
    President:
  • 1,653 Answers
Try resetting the unit settings back to default. This should cure the problem
Posted on Oct 08, 2009
Error 1100
Try to wipe it clean. Aka hard reset. Lots of vids on youtube.
Turn off
Press power + vol up
When logo appear release power. Still hold vol-up until green android appear.
Now you can navigate menu with vol up/dn and select with powerbut
You will select factory reset
Scroll past no no no to yes
Scroll to reboot
Maybe its an app you installed? My S4 mobile started rebooting all the time by itself after intalling a kids game!
Regards
Liz
Aug 17, 2013 | Tablets & eReaders
I just recently got directv installed and ever since my volume on my sansui tv turn down by itself any idea why
Hi:
Most cable or satelite boxs have their own volume controls try using the boxs remote to change vol levels to see it this solves your problem.
May 22, 2011 | Televison & Video
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
Hi-Our GE spacemaker phone will no longer record messages when someone attempts to leave a message. The phone will just ring and never attempt to record. It was working fine for until recently. We have...
Apparently you have the answering machine turned off.
When speakerphone is OFF (not in TALK mode), press flash/program button and CID VOL(+) / CID VOL(-) arrow keys to move the pointer > to point at ANSWER ON/OFF, press flash/program button to show SET ANSWERER ON OFF.
Use the CID VOL(+) / CID VOL(-) arrow keys to select ON.
If you need one, you can download the manual here.
Feb 09, 2011 | GE Spacemaker 26976 Cordless Phone
Sony HCD DX150: when we put the volume up past 29 the system shuts down and we have to unplug then plug in again to restart it.
Hello: You have a bad speaker on the system. Try disconnecting one speaker one at a time while turning the vol past 29. Until you discover when it stays on pass this point. Example you know it shuts down after 29, so start with the front right speaker disconnect it and turn vol pass 29 to see it it cuts off is so then the bad speaker is still connected to system, do this for all speakers until it does'nt turn off, when it does turn off you have removed the bad one. This is just to make sure its a speaker causing shut down, and not the amplifier it self...
Dec 06, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
On off switch
clean front panel contact switches on/off vol- vol+ use contact cleaner .
Dec 03, 2008 | RCA D52W19 52" Rear Projection Television
After fixed CD problem, reinstalled. without engine on, all function works but when engine is on, steering whell radio controls; Vol Up/Dn goes funny. Vol. Down makes vol. up and Vol up moves stations. ...
It turned out that problems were in sterrieng switches resistance as not contacts in switches themselves. Opened switches and lubricated bit. Problems gone. Thanks for some interests and hints for this problems.
Sep 08, 2008 | Car Audio & Video
Philips FR975 Receiver Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
