Question about Minolta 35-80mm f/4-5.6 II Lens
Lens front cover
The camera lens front cover opens but do not keep being opened. what shall i do? pls help.
  • 619 Answers
Visit camera store bring your camera lense show what cover , for temporary cover a soft cloth keep .put absorbent shashy.
Posted on Jan 01, 2008
I have nokia N72, camera is not working, after opening lens cover camera does not start, when i start camera going through imaging>camera, it shows the message "camera on standby, open lens cover" need...
@ above
dude im also facing da same problem( with N72)...hv u got any solution..coz i can see that ur post is almost a month if u hv any solution then pls temme..
Sep 29, 2010 | Nokia N72 Cellular Phone
When i turn it on it says turn off and on again
I have just had exactly the same thing on my daughter's NV3. In this case the lens cover would not open but if you power on the camera with you finger on the display button you can view stored images. If the lens cover is jammed you need to open the casing and maybe take the lens cover assembly apart. You need a very small cross head screwdriver (No.00 should be OK). There are 5 screws in total, 4 screws on the outside of the case (3 plus1 under the headphone socket cap) and 1 inside the battery compartment. You need to remove all 5 to remove the camera front casing. There are some retaining springs top and bottom on the front cover, gently prize off to reveal the lens cover assembly. Check to see if the lens cover will operate by switching on and off - if it works then the camera front casing is preventing it from opening and is probably bent out of shape. A little careful bending back into shape should resolve the problem. If it still does not work with the casing removed, read on. This is the tricky part. There are two extremely small, black retaining screws to the left hand side which hold the assembly onto the lens cover motor. Remove these screws and the front of the lens cover assembly to reveal the lens cover and the back plate of the assembly. Lift off the lens cover and switch on the camera. If the motor is still working, you will see a short black peg move from side to side as you turn the camera on and off. Thoroughly clean the lens cover and assembly, remove any obstruction and replace the lens cover making sure you locate the hole in the lens cover over the motor peg (described above).
The motor is magnetic and will attract the screws away from their holes if you replace the assembly front straight away, so when you replace the front of the lens cover assembly, place the screws in the correct holes before lowering it into place and then screw onto the motor/assembly back. Test that the lens cover opens and closes and replace the Camera front cover taking care not to bend it too much - if this becomes distorted it can stop the lens cover from operating resulting in the same problem.
Apr 01, 2010 | Samsung NV3 Digital Camera
Lens needs to be manually opened
I just repaired this problem on my daughter's camera today! I took out the 4 tiny screws that hold the front cover on and discovered gunk and goo that were keeping the lens from retracting. Please note the exact position of the screws. They are different sizes. I then very carefully cleaned all the residue using Q-tips dipped in rubbing alcohol. It worked perfectly! Just like new.
Jun 20, 2009 | Kodak EasyShare V610 Digital Camera
Lens cap will not stay open
try opening your camera in front unscrew the bolts and pull the front will see a metal cover not properly align.
Apr 06, 2009 | Kodak EasyShare V570 Digital Camera
My camera is getting vibrate when i open the lens cover
Sounds like the steady shot mechanism has went haywire.
Replace the whole lens assembly to repair it.
Jan 09, 2009 | Cameras
Lens cover won't open
You should look for "lens cover mechanism" when open camera front cover. This part has defective gears or misaligned some thing internally. Part detail is as under for Sony DCR-DVD653E model.
( 1-787-236-11 ) MOTOR UNIT (LENS BARRIER)
You can have an idea of this part in below exploded view... I hope these info will be useful.
Oct 29, 2008 | Photography
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Zoom lens/flashlight don't retract.
replace zoom lens strip and please do let me know where it is available I too have the same problem
Jan 12, 2008 | Kyocera Finecam S5 Digital Camera
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Automatic lens cover is stuck
The lens mechanism is damaged.The only known solution is to get a replacement lens unit and replace it
Aug 08, 2007 | Vivitar Vivicam 5388 Digital Camera
Minolta 35-80mm f/4-5.6 II Lens Logo
67 people viewed this question
Top Minolta Cameras Experts
Tony Parsons
Tony Parsons
Allen Showalter
Allen Showalter
Level 1 Expert
Are you a Minolta Camera Expert? Answer questions, earn points and help others
