Question about Kenwood Excelon KVT815DVD Car DVD Player
I need to know the color of the back up camera wire on the kenwood harness to run to vehicle reverse wire
  • 54 Answers
The pink goes to revers and when looking ata the back of the player third row top yellow is your visual input
Posted on Oct 07, 2009
Kenwood kdc-x399 troubleshooting
Check Kenwood wiring color code and function against vehicle harness color code and function. They are not always the same.
Aug 03, 2016 | Kenwood Car Audio & Video
I need the wiring codes and diagram for a kenwood
You should got the factory crossover harness would been no colors to match and you wouldnt need cut the factory harness. Crutchfield sells them for every vehicle made. Striped wires are speakers dont hook up the orange wire at all that the illumination black is ground red is constant power
Oct 18, 2014 | Car Audio & Video
I need a color coding of the wiring for the harness i was given for my kenwood dpx308u. i just need to know which colors belong to which wires
Ok, you should have a wiring harness that plugs into the radio. That comes with the radio. You will need a wiring harness that is specific to your vehicle, this will plug into the vehicle harness. The wiring harness will have the correct colors to attach your radio to it. All aftermarket radios have standardized wiring. I recommend not attempting to hardwire your radio due to the risk of frying your entire electrical system. I hope this helps.
Aug 19, 2011 | Car Audio & Video
Im tring to match up this radio wireing to a chrysler lhs i need to know what colors go to what the kenwood krc 235 wire to the chrylser car wireing (red to pink blue to orange like that)
I recommend you purchase a wiring harness specific for that vehicle instead of trying to hardwire it. You run the risk of frying your entire electrical system if you do. Wiring harnesses are about $7-$20. Plus, it takes the guesswork out of wiring. Visit www.crutchfield.com if you are looking for one.
Aug 14, 2011 | Car Audio & Video
Need to know how to hot wire ignition.what color wires do i use?
1991 Ford F150
Vehicle Battery Positive Wire (+): Yellow
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Red/Light Green
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): N/A
Vehicle Second Ignition Wire Location: N/A
Vehicle Accessory Wire (+): Gray/Yellow
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): N/A
Vehicle Second Accessory Wire Location: N/A
Automobile Engine Starter Wire (+): Red/Light Blue
Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): N/A
Automobile Second Engine Starter Wire Location: N/A
Factory Anti-Theft System: None
Factory Anti-Theft System Type: None
Car Key Sense Wire (-): Black/Pink
Car Key Sense Wire Location: At Steering Column Harness
Car Neutral Safety Wire (+): N/A
Car Neutral Safety Wire Location: N/A
Car Tachometer Wire (-): Tan/Yellow
Car Tachometer Wire Location: At Ignition Switch Control Module in Driver Fender Well
Car Speed Sense Wire: Gray/Black
Car Speed Sense Wire Location: Pin #3 at PCM Mounted on the Firewall
Car Parking Lights Wire (+): Brown
Car Parking Lights Wire Location: At Headlight Switch or Driver Side Kick Panel
Car Brake Lights Wire (+): Green
Car Brake Lights Wire Location: At Brake Switch Above the Pedal
Car Reverse Lights Wire (+): Black/Pink
Car Reverse Lights Wire Location: At Switch on Transmission
Car Horn Wire (-): Blue
Car Horn Wire Location: At Steering Column Harness
Sorry friend, this is as far as i can go to tel you how to hot wire the ignition. But with the color codes you should be able to figure it out, Good luck and keep me posted.
Jan 23, 2010 | 1991 Ford F150
Trying to hook up last few wires and not sure what they are
Hello jtracer,
Here's a link to the Kenwood manual at Crutchfield.
Here's a link to the color code for the 2000 Dodge Durango.
If you are splicing directly into the vehicle wiring, just match up the wires from your Kenwood to the appropriate vehicle wire by function, not color. If you are using an aftermarket vehicle specific wiring harness, such as the Metra 70-1817, the colors should match up with the Kenwood wires.
Hope this helps.
Aug 31, 2009 | Kenwood Excelon KDC-X789 CD Player
I am trying to connect a kenwood KDC-MP3035 to a 1997 Honda Passport but none of the wires match up, what do i do to make it work?
Hello oz101ez,
The wires have to be matched by function, not by color. Here is a link to the color code for the stock radio harness in your Passport. Connect whatever color wire your Kenwood manual says is for 12V + (usually yellow for most aftermarket receivers) to the "red/white" in your Passport. Connect the Kenwood accessory wire (usually red) to the brown/white wire in your passport. Just continue matching up each wire function and colors on both ends.
Best would be an aftermarket wiring harness vehicle specific for the Honda Passport/Isuzu Rodeo. The Metra 70-7712 seems to be the correct one for your vehicle. Installer.com probably has the largest selection of wiring harnesses available anywhere. They'll even match the vehicle harness to an aftermarket receiver harness and connect them using solder and heat-shrink insulation if you desire.
Most local car audio shops will carry some wiring harnesses. Also retailers like Best Buy may have them, albeit at much inflated prices. Online car audio retailers like www.crutchfield.com and www.soncielectronix.com have a good selection and their prices will probably be somewhere in between, lower than local but higher than Installer.com
Hope this helps.
Aug 05, 2009 | Kenwood Car Audio & Video
Need wiring harness for kenwood kdc-mp225
Okay there are 2 possible solutions depending on your problem
Number 1
If its the lead that plugs into the back of the headunit then this is the page you need Click Here All you have to do is choose the one you need! just look at how many pins there are pretty simple to work out
Number 2
If its the lead that plugs in from your car loom to the headunit loom then you need to look here and pick out your car
This will solve your problems :)
Upfront Audio
Please dont forget to rate :)
Apr 23, 2009 | Kenwood Sirius KDC-MP225 CD Player
Splicing the wiring from a kenwood excelon kdc-x589 unit to a jeep harness
For the Kenwood KDC-X589:
yellow - always on B+12 such as battery + terminal
red - switched B+12 such as ACC of IGN switch
black - body/chassis ground (- battery)
orange/white - dimmer control wire (car light control switch)
gold - to my knowldege no gold
brown - mute control from mobile phone
pink/blk - external amplifier control/trigger wire
blue/white - power control wire similar in function as the orange/white
blue/blk - to my knowldege no blue/blk
blue - motorized/power antenna
For the vehicle, pls postback info on year and make/model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 13, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
OR
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Jango
Dec 11, 2007 | Kenwood DDX7019 6.95 in. Car Monitor
Kenwood Excelon KVT815DVD Car DVD Player Logo
122 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
