Rank: Guru
Rating: 91%, 229 votes
Hi larry_per983,
When you first set up your
X6 wireless network, security is turned off by default. This means that your wireless signal is not encrypted and that anyone with compatible wireless technology can access your computer network and the Internet using your wireless connection.
To set up wireless security, you will create and enter a unique passphrase or an alphanumeric key. Once entered, only devices with the proper key or passphrase will be allowed to establish a connection to the network, which you may have already done.
There are two basic ways to configure and implement a passphrase or key. They are WPA (WiFi Protected Access) or WPA2 and WEP (Wired Equivalent Privacy) 64 and 128 bit. WPA2 is best, but you can use it only if all your wireless devices support the 802.11g profile, followed by WPA and WEP, in that order.
Setting Up Security Using WEP
Before proceeding, if you have not read our FAQ "Wireless Security - An Overview", please
Click Here
If all of your network devices DO NOT support WPA2 or WPA, you can use WEP to configure network security.
WEP can be configured in two ways, 64-bit and 128-bit. 128-bit WEP provides a bit more security than 64-bit, but 128-bit WEP also tends to diminish network performance. We recommend that most people configure their WEP for 64-bit security.
Click the Wireless icon in the Zoom Configuration Manager. This will open the Wireless Setup page.
Go to Encryption (which should say None) and select WEP-64 bit (or WEP-128 bit for more security, but diminished network performance) from the drop-down menu. Six new boxes open directly below the Encryption box.
Check the box marked Passphrase and then choose and enter a Passphrase. You can enter a word or a phrase, or for greater security you can enter a combination of numbers and letters. The Passphrase is case-sensitive and can be up to 8 characters.
If ALL of the wireless devices (clients) on the network are Zoom devices, go to step A. If some or all or the devices are not Zoom devices, go to step B.
A. If ALL of the wireless devices (clients) on the network are
Zoom devices, you need to enter the Passphrase that you just created for each device. Every wireless network client needs to be set individually. Open the software that came with the device, which should be running on the computer where the device is installed. Find the configuration menu for security, choose WEP, and enter the Passphrase, exactly as you entered it on the
X6 Wireless Setup page.
Your security setup configuration is now complete!
B. If any or all of the other wireless devices on the network (clients) are
not Zoom devices, you will enter one of the keys shown below the Passphrase on each client. You must enter the same key for each device. The key that you must use is the key corresponding to the Default Key number shown. If the number in the default key box is 1, use Key 1, and so on. You can choose the default key you prefer using the pull-down Default Key menu box.
Now that you have a key, enter it for each client. Every wireless network client needs to be set individually. Open the software that came with the device, which should be running on the computer where the device is installed. Find the configuration menu for security, choose WEP (64-bit or 128-bit depending on what you selected), and enter the Default Key, exactly as it appears on the
If you follow these instructions correctly, your internet light will beam correctly.
Good Luck,
And don't forget to leave a rating.
Thanks
Mark
Comments:
Oct 08, 2009
- Ok,
Question, without turning on the security all lights are green?
MarkOct 09, 2009
- Hi larry_per983,
I think I know what might be wrong. Did you configure your internet Explorer settings to connect to the router? You will need to manually set up your settings to get access through the router with the security turned on. If you've tried this, please list your setting on a follow-up post.
Thanks
Mark
