Question about Samsung SGH-D500 Cellular Phone
Really need to change front lens but how
Hi I really need to change front lens cover can I do it from front or will I have to do from inside
  • candyflip Apr 17, 2008
    Im using the the samsung d820. how do u disconnect the flat cable with the two connectors. im trying to change the cover. plz help
  • 137 Answers
Sorry if you able to you must strip it completely. Be Carefull , there is a flat cable and 2 connectors inside that damage very easily.Then your fone can be dead, lights, no mic, or no sound.
Posted on Dec 25, 2007
How do I get to and clean the inside of both headlamp glasses because my car failed the MOT because the inside of the headlamp units are very dirty. Not the reflector but the front plastic cover.
Dec 18, 2014 | 2002 Hyundai Santa Fe
Hi, Might it be the lens? The exposed portion of the lens do get covered with grime and dirt, maybe not much but when used, it gets baked because of the heat from the lamp. Cleaning it by wiping is not enough. You have to use a solvent to really clean it. One thing to remember is to clean it when it is at room temp and not after use (even a short one). The sudden change in temp is not that healthy for the lens. Since you were able to change the lamp, perhaps you can also do the inside portion of the lens. Treat it like your eyeglasses or the windshield of your car. Sometimes you really have to rub on it hard to remove the stains and smears. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | InFocus ScreenPlay 4805 Multimedia...
My 2007 new beetle's right rear light has moist inside. How is it?
your seal betwen the case and lens is bad best to replace
Jan 16, 2011 | 2007 Volkswagen Beetle
Dust inside lens
this can be a doozy, but if you are up to it, remove the top cover, you may have to remove the rear, front and maybe sides, i don't know, but what you are after is the cover over the top of the lens. take that off and use air to blow it out--don't touch anything, just blow. several bursts then quickly replace the cover over the lens assy. if used in a dusty environment or ceiling mounted, you may have to do this as needed.
May 20, 2010 | Optoma HD65 DLP Projector
When i turn it on it says turn off and on again
I have just had exactly the same thing on my daughter's NV3. In this case the lens cover would not open but if you power on the camera with you finger on the display button you can view stored images. If the lens cover is jammed you need to open the casing and maybe take the lens cover assembly apart. You need a very small cross head screwdriver (No.00 should be OK). There are 5 screws in total, 4 screws on the outside of the case (3 plus1 under the headphone socket cap) and 1 inside the battery compartment. You need to remove all 5 to remove the camera front casing. There are some retaining springs top and bottom on the front cover, gently prize off to reveal the lens cover assembly. Check to see if the lens cover will operate by switching on and off - if it works then the camera front casing is preventing it from opening and is probably bent out of shape. A little careful bending back into shape should resolve the problem. If it still does not work with the casing removed, read on. This is the tricky part. There are two extremely small, black retaining screws to the left hand side which hold the assembly onto the lens cover motor. Remove these screws and the front of the lens cover assembly to reveal the lens cover and the back plate of the assembly. Lift off the lens cover and switch on the camera. If the motor is still working, you will see a short black peg move from side to side as you turn the camera on and off. Thoroughly clean the lens cover and assembly, remove any obstruction and replace the lens cover making sure you locate the hole in the lens cover over the motor peg (described above).
The motor is magnetic and will attract the screws away from their holes if you replace the assembly front straight away, so when you replace the front of the lens cover assembly, place the screws in the correct holes before lowering it into place and then screw onto the motor/assembly back. Test that the lens cover opens and closes and replace the Camera front cover taking care not to bend it too much - if this becomes distorted it can stop the lens cover from operating resulting in the same problem.
Apr 01, 2010 | Samsung NV3 Digital Camera
I need to know how to get the tail light lens cover off to change signal bulb
Open hatch and on inside of body where the lens is are two horizontal screws going into the lens, remove them and pull the lens towards the back of the vehicle carefully. Good luck
Apr 27, 2009 | 2006 Dodge Caravan
Hi. I took my sony dsc t1 digital camera a part and small pin fell from the inside. do you know where it goes to?
that small pin is for support and not to bend front cover towards lens mechanism.
Small pin will be installed in center of lens assembly with head upward.
Let me know if you need further info.
Apr 06, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lens cover won't open
You should look for "lens cover mechanism" when open camera front cover. This part has defective gears or misaligned some thing internally. Part detail is as under for Sony DCR-DVD653E model.
( 1-787-236-11 ) MOTOR UNIT (LENS BARRIER)
You can have an idea of this part in below exploded view... I hope these info will be useful.
Oct 29, 2008 | Photography
Lens error, restart camara issue in SD900
well **** that doesnt sound complicated or anything.
Feb 29, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Samsung SGH-D500 Cellular Phone Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
